Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
  #91
Old November 9th, 2015, 12:14
dornbos's Avatar
dornbos dornbos is offline
Re: Aw4 power handling/ reliablity and performance upgrades.
There are 2 threaded holes in the transmission pump that allow the pump to be pulled out. Does anyone know the thread size on those. I'm not doing too good on guessing.
thanks.
Old November 10th, 2015, 17:42
dornbos's Avatar
After multiple trips to the store, I learned that the thread size of these holes is M10 with a 1.25 pitch.
Now if I could just get the pump to budge!
Old January 24th, 2016, 20:50
rockosocko rockosocko is offline
You're supposed to use a slide-hammer type of attachment like with GM transmissions. (one in each hole)
Look into renting a slide hammer from an auto parts store or go to harbor freight and get to and take one back later..
On going back together, you can get one of those wire lip seal installers.
It's a simple metal pipe with a thin tough wire looped around and crimped back in the end of pipe.
You use it like a kind of 'shoe horn' (and a lot of lube/assembly grease/vaseline.) and slide the wire end around seal to bend the lip back in so it won't get cut by the mating surfaces.
EVERY trans shop knows what they are..
Errol
Old October 31st, 2016, 07:31
hjeepxj's Avatar
hjeepxj hjeepxj is offline
#OCDINK
SUBSCRIBED - great thread!
2000 XJ 5.5" Lift w/Deavers and TNT arms, 30 front w/Super 30 kit, ARB, truss, etc. 44 rear w/35 spline alloys, ARB, Wilwood discs, truss, etc. Hooligan stiffeners front to rear, Hooligan fenders, Trailready front bumper, JCR rear bumper w/tire carrier. *under construction*
Rate This Thread:
Lift kit handling performance? twistedlizard720 Modified Tech Discussion 22 January 7th, 2010 21:46
XJ performance upgrades? Hydrolock Jeep Street and Performance 16 November 12th, 2008 18:58
*Weekend Performance Upgrades* cpolish24 Jeep Street and Performance 15 October 15th, 2008 07:10
Performance Upgrades Starboard M Jeep Street and Performance 18 April 9th, 2005 18:13
airflow performance upgrades BLUTO Modified Tech Discussion 9 April 23rd, 2003 23:15
