ax-15 shift problem
thatguytrav
Charleston, SC
Sooo my jeep started shifting kinda funny on the way home. It slowly starting getting harder to shift.. then it didn't want to go into 1st or 2nd.. then 3rd and 4th. now I'm locked out off all gears minus reverse and all it does is grind when I try to put it in reverse. I checked the fluid and it seemed pretty full. Any ideas???
Put in an automatic. I am just messing with ya, although I like the auto better myself. I am just bored from sitting on the side of the road with my broke heep for 5.5 hours. Just ignore me.
Man... don't everyone jump at once :p Well, I went to work on the xj yesterday and everything worked/looked fine. I haven't found signs of a culprit but I was leaning more towards the master or slave cylinder but there are no signs of them leaking so not sure how else to test them.
It's working fine again and no slipping... The only other thing is I can hear a squeak from under the hood when I push the pedal in but I figured that was normal
Sometimes yes but you may be having a master/slave problem.
