I have all the necessary brackets and hardware to mount a XJ Warn Front Bumper. The cool thing is that with these brackets, it stiffens up the front end and makes a flat surface to make your own front bumper. All of the 4 large brackets are new and it includes the necessary bolts and hardware to mount it including instructions. These brackets allow for a 14 point tie in with the front bumper. With these brackets you will be able to use a 9500 lb winch (assuming the bumper attached to it is made well enough and is mounted to the 14 points these brackets provide / the Warn front bumper is rated 9500 lbs with this hardware). $60 plus freight from 90221.
PM me for pics. I will respond within a couple of days.
Thanks
CRACKER
Thanks
CRACKER
