OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Remanufactured motor questions couple of questions....
I might have a chance to pick up a remanufactured 4.0 for 500 bucks and wanted to get a couple questions answered.
Its remaned by Hesco Parts - anyone have any experience with them? Also I was told it was made for a 1998 with vin code "S" and has the straight oil filter mount. Will this fit my 2001? I'm gettin ready to redo the rod/main bearings and that'd run me 300 or so with parts and I figured this might be a smarter move. Unfortunatly the motors warranty in not transferable. |
#2
Re: Remanufactured motor questions couple of questions....
Given the price of the rebuild, I can see why it'd be a tough call.
What kind of shape is the rest of your engine in? Rob
1992 Cherokee Laredo: "A wonderful balance of grace and rust" 1984 Dodge Omni 2002 Volkswagen Jetta GLS TDI |
#3
The rest is great. Just a little valve noise which seems to be common for the 4.0.
#4
BTT
#5
The brackets that hold the motor mounts are a different setup for the 'straight filtered' 4.0L that normally is used on TJ's.. I wouldn't go that route unless you are extremely handy with making motor mount brackets on your own and drilling and tapping 6-12 holes for accessory bracket \ mounting differences between the TJ an XJ... *don't do it in my opinion*
George T. Quote:
#6
Thread Tools | |
Display Modes | |
Couple Questions | Zoro | OEM Tech Discussion | 16 | March 28th, 2006 19:28 |
Couple questions | jeepguy97 | Modified Tech Discussion | 2 | August 19th, 2005 16:40 |
Couple of RE / DPG questions | Harvo | Modified Tech Discussion | 11 | December 27th, 2004 09:32 |
got the "new" motor in...couple of questions | trouble1 | OEM Tech Discussion | 2 | February 27th, 2004 20:24 |
couple of questions | family XJ | OEM Tech Discussion | 3 | January 4th, 2004 19:52 |
