Old August 9th, 2005, 17:13
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
A few fuel pump questions and 1 exhaust questions
When I changed my fuel pump the other day, I am 99% certain that I didn't mess up the +/- connection on the pump. After changing it, I got it to start and run for almost 2 minutes. If I had them on wrong, it wouldn't have run at all right? It has not started since, by the way.
The Chilton guide says to be sure not to swap an MPI for a TBI fuel pump or vice versa, but it show an MPI pump for pre-1996 in the guide. Mine is a 1990, so is there anyway possible, I had an MPI and swapped in a TBI, or are there enough differences that I would tell on the install? The one I took out and the one I put in were vertially identical.
If I cut my exhaust pipe with a sawzall, to seperate components (since they are rusty) to check for a possible clog, I could just get a sleeve and sleeve over the cuts ans secure it with 2 muffler clamps to repair the cut damage, correct?
I am almost to wits end with this dang machine.
Dirk DeYoung--Member #176
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2006 XK (TOW RIG)
Old August 9th, 2005, 17:33
langer1's Avatar
langer1 langer1 is offline
Re: A few fuel pump questions and 1 exhaust questions
Dangit man keep the same thread open untill you get this thing running, your going to be even more confused than you are now it you dont.
Old August 9th, 2005, 19:13
Cottontail's Avatar
Three-De Off-Road
I thought about that, but it seems that after about 12 hours, no one reads or responds to the posts, so when my question changes, my thread changes!!
Old August 9th, 2005, 19:16
langer1's Avatar
Every new post comes to the first page and will get a responce.
Welder QUestions Kejtar Tow Rigs and Trailers 10 June 11th, 2007 09:11
