Old June 3rd, 2005, 11:53
barns12 barns12 is offline
Thumbs down ZJ Wheels to XJ?
I have a 98 ZJ Limited with 16" wheels. I want to swap them onto my 2000 XJ as I'm selling the ZJ and want to keep my new BFG's. Will the swap work both directions? Thanks for any help!
Old June 3rd, 2005, 12:12
96XJCLASSIC's Avatar
96XJCLASSIC 96XJCLASSIC is offline
Re: ZJ Wheels to XJ?
If you are asking if the bolt pattern is the same.... The answer is YES.
Old June 3rd, 2005, 12:57
Red face Re: ZJ Wheels to XJ?
Would you know if the back spacing are the same and the clearance of the 15" XJ wheels to the ZJ rear calipers and rotors, as the ZJ wheels are 16"? Thanks again!
Old June 3rd, 2005, 13:12
I don't know the backspacing exactly but I would say probably around 5". I don't know if they would be the same bs or even the same width. However ZJ's came with both 15" and 16" rims from the factory so I would say that brake clearance shouldn't be a problem. Even if the backspacing would be different it shouldn't cause a problem either it would just cause the wheels to stick out a little farther or vice-versa.
5 Stock XJ Wheels azdesertrhino For Sale: Private Party Only. XJ ITEMS ONLY 2 May 4th, 2005 21:14
ZJ, XJ coil questions 87CherokeeChief Modified Tech Discussion 18 August 26th, 2004 13:38
XJ vs. ZJ Track Width & Stretched XJ Nay Modified Tech Discussion 41 August 25th, 2004 17:12
What year ZJ pitman will work on XJ Stick Modified Tech Discussion 4 February 2nd, 2004 19:10
RE 3 inch ZJ Spring on XJ Duane Modified Tech Discussion 4 January 16th, 2004 16:02
