Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
need help with wheels
im going from 33's 12.50 15's to 315 75 16's. i was running an 8 in wheel with 4 in back spacing. should i do the same for the 315's, only in a 16 x 8 or should i go to a 16 x 10? what back spacing would you recomend?
my current set up consist of re drop brackets , jks adj uppers and lowers, 8 in sky jacker coils, a re hd track bar and bracket, and a skyjacker drop pitman arm, with re 4.5 leafs, 1in block and 1.75 shackle and rancho rsx shocks . probably more info than you need but now you know what i have to work with. tia trey |
#2
Re: need help with wheels
The 315's are essentially 35x16x12.5 if I remember correctly (didn't do the math). So from your current tires you are simply adding 1" of tire diameter.
A 16x10 rim will cause the tires to stick out 2" further than they do now. Is this what you want? You will need a lot more trimming to make that fit than keeping them on an 8" rim. 4" of backspace should be fine - I would not do any more than that, and personally prefer 3.75", but that may be hard to find in the 5 on 4.5 bolt pattern. So...if you like what you have now and just want bigger tires, stay with the same rim width/backspace. If you want those tires to stick way out, go with the 10" rim. Why the LT tire, by the way, instead of a 35x12.5x15 keeping you same rims. No way an XJ needs that extra load rating, and the tires will be more expensive with much stiffer sidewalls. Just get a set of 35's and keep your rims....probably save you $500. Nay |
#3
thanks for the reply. im going to 16's so i have clearance for wj calipers and rotors since im doing the wj knuckle conversion like this one
http://www.orgsmfg.com/project/WJKnuckle.htm |
Thread Tools | |
Display Modes | |
Misc. All Terrain Tires and Wheels | mdemic | For Sale: Private Party Only. XJ ITEMS ONLY | 3 | April 18th, 2004 11:35 |
Wheels, Backspacing and 31" BFG's | markpr | Modified Tech Discussion | 5 | February 15th, 2004 15:57 |
36" SXs, 35" MTs, 35" ATs, and Wheels, CHEAP in CA | morenmoretoys | For Sale: Private Party Only. XJ ITEMS ONLY | 3 | January 26th, 2004 10:34 |
Nor Cal: Wheels and Tires Needed | Jeddi | Wanted: Private Party Only | 6 | January 14th, 2004 18:14 |
Alcoa M/T Challenger One Piece FORGED Aluminum wheels | Instaurare | Modified Tech Discussion | 11 | June 17th, 2003 20:42 |
