Old January 10th, 2018, 17:50
Precious88xj Precious88xj is offline
Coolant temp sensor renix idle problems?
1988 Jeep xj 4.0 4x4 aw4
So I recently swapped in a high output motor and forgot to install the coolant sensor that mounts to the motor on the renix. I kept my electrical system from the renix. Would that cause me a rough idle I donít have it connected?
Also I wonít be able to install it to itís original location can I adapt it to the water outlet where the temp sensor goes located for the H.O
Old January 11th, 2018, 10:31
90xj06's Avatar
90xj06 90xj06 is offline
Re: Coolant temp sensor renix idle problems?
order a thermostat housing from a 93 4.0 and put your temp sensor in there. your going to need to make a longer harness.
it would change timing and mixtures a bit when its missing.
Old January 12th, 2018, 04:46
cruiser54's Avatar
cruiser54 cruiser54 is online now
It needs that sensor for sure.
Too hard to get the plug out of the block now.
Old January 13th, 2018, 12:18
JeepNoob JeepNoob is offline
So I recently swapped in a high output motor and forgot to install the coolant sensor that mounts to the motor on the renix. I kept my electrical system from the renix. Would that cause me a rough idle I don’t have it connected?
Also I won’t be able to install it to it’s original location can I adapt it to the water outlet where the temp sensor goes located for the H.O
Yes, it will cause idle problems. The PCM needs to know if the engine is hot or cold (among other things) to adjust fuel accordingly.
If your factory temp sensor will fit into an HO thermostat housing, I would simply cut the wires a few inches away from the connector and splice in some new wire. If you can solder, I would recommend that and some heat shrink tubing. If not, most parts stores sell butt connectors with a heat shrink plastic "jacket" that also work very well.
Old January 13th, 2018, 13:46
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
I am not sure, not convinced a missing CTS sensor will cause idle problems. Simple test is to connect one to the wiring, just do not install it in the block. Cool the sensor with cold water, then heat it with boiling water. That will tell you if it is affecting idle or not.
If the O2 sensor and IAT temp sensor are working I would think it could it idle fine (closed loop).
Not having a CTS can affect starting the jeep (probably hard to start, easy to flood sometimes)!!!!
And it can waste gas!!!
Old-Man had a bad one, it was telling the ECU the temp was 30F or something all the time, and his problem was the ECU would not switch to closed loop, and it stayed open loop and drank gas big time, but he did not mention an idle issue. I think it was Renix. I think the ECU will assume an acoolant temp, guess, and then use the O2 sensor to control fuel feed.
IF the O2 sensor is having issues, fuel injectors have issues, or a dozen other things, then that is the probable cause of the idle issue.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old January 14th, 2018, 10:04
cruiser54's Avatar
I'll guarantee a missing CTS will cause problems.
Old January 14th, 2018, 10:23
Hypoid's Avatar
Hypoid Hypoid is offline
Flores helped me diagnose a bad CTS: It idled great, ran great, never went into closed loop, could not pass emission testing.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old January 14th, 2018, 11:17
Ecomike's Avatar
NAXJA# 2091
I never said it would not cause problems, but I still say it will not cause a bad idle/problem if the other sensors and hardware are working!!!
"Coolant temp sensor renix idle problems?" is the title of the OP post.
But I agree with you, it will cause many other issues. For one it controls the initial fuel feed rate when cranking on start up!!! Because at that time it has no O2 sensor data!!! It is critical for start up fuel rates!!!
Old January 14th, 2018, 11:23
Ecomike's Avatar
NAXJA# 2091
Well that confirms it. I am pretty sure old_man had the exact same story, his was sucking up fuel like a mad dog as the CTS was passing out bad coolant temp data to the ECU, claiming the block was always super cold, or something like that.
Depending on the bad data, random change in the reading, or always reading cold, warm or hot, would likely create different issues. One might be hard starting when cold, the other starting when hot. IMHO. But in Old_mans case it would not go to closed loop either, due to bad CTS, thus it wasted gas big time.
So a missing CTS needs to be fixed!!! But doing so fixes other problems, not a wandering idle!!!
Old May 1st, 2018, 17:27
randy57 randy57 is offline
93' thermostat housing will fit the 90 renix?
Also isn't it better to have the CTS in the block where the water has not had a chance to cool before going into the radiator?
Old May 1st, 2018, 17:45
Ecomike's Avatar
NAXJA# 2091
In the head is better, you can see the coolant temp before the T-stat opens, if it opens. In the T-Stat housing, you do not see the coolant temp tell the T-stat opens if it opens. I Think the HOs had it in the water pump outlet feed to the heater, which bypasses the T-stat. That would see the hottest water in the entire system, whether the T-stat is open or not
Old May 1st, 2018, 18:23
Mine is in the side of the block, miserable to get to. Though it would be good to have it in the thermostat housing, that way it could be changed without loosing too much coolant. Do you think the later years housing would fit the renix?
Old May 1st, 2018, 19:03
Ecomike's Avatar
NAXJA# 2091
You have three coolant temp sensors. One in the radiator drivers side, on on the top rear of the head, and the one you mentioned. One is a temp-switch to cycle the E-fan, one for the dash gauge (on the rear of the head drives side) last goes to the ECU for fuel and air trim
Old May 1st, 2018, 20:27
cruiser54's Avatar
The one in the radiator is a fan SWITCH.
The one in the block is a coolant temp SENSOR.
The one in the back of the head is a temp gauge SENDER.
Old May 2nd, 2018, 12:39
Ecomike's Avatar
NAXJA# 2091
Also note the Temp gauge sender comes in two flavors, and idiot light switch, and a temp gauge variable resistor/sensor
88 XJ Renix Coolant Temp Sensor Rplmnt ptf18 OEM Tech Discussion 5 February 27th, 2016 16:10
Coolant Temp sensor for RENIX, location after swapping to HO. stockli OEM Tech Discussion 7 April 3rd, 2010 21:07
Renix Coolant Temp Sensor question.. stephenspann27 OEM Tech Discussion 18 January 13th, 2010 07:34
Coolant temp sensor problems maybe? 98XJSport OEM Tech Discussion 2 August 30th, 2005 09:22
Coolant Temp Sensor causes High Idle RENIX? Storydude OEM Tech Discussion 3 June 8th, 2005 18:34
