I went to change it today and came to find out I have a weird lower main seal that does not seem to want fit the seal with the tap/wings. Basically I need two seals that looks like the upper. Has this happened to anyone else?
This should explain everything. READ EVERY POST... because the problem is resolved towards the end. DO NOT CUT the tabs off...it might leak (probably will). Oil pan gasket info included in the thread below also.
