Old January 11th, 2021, 00:30
Benthos Benthos is online now
Xj replacement manifold included gasket gotten better?
The consensus is always been that the replacement manifold are fine but the included gasket is garbage. Looking at what came with the header it looks like it has quite a bit of metal in it and it looks like it's a minimum of double the thickness of the OEM.
Are these the same gaskets that everyone says are junk?
When you read the Amazon reviews there's hundreds of people that are putting them in there with good results right now.
Felpro looks pretty thin and some people here seem to have had leaks.
Is it remflex or bust?
Old January 16th, 2021, 03:25
Re: Xj replacement manifold included gasket gotten better?
Well I couldn't find anyone confirming the included gaskets were ok so I went with the Remflex.
https://imgbox.com/2X61ZjD4
I gotta say if I had to do it over I would use this again. I don't think these China manifolds have a perfect fit up. After the torque sequence some areas were closer to the head than others. However it seems to make no difference with this gasket. It's so thick it soaks up everything. I just did 23lbs, says no re torq is needed. Def worth the $40 I think.
Intake manifold and exhaust manifold gasket replacement.... 1990Pioneer OEM Tech Discussion 4 August 9th, 2011 05:24
? which FelPro int-exh manifold gasket for '99XJ 4.0L with tube-style exh manifold ? MikeESoc2 OEM Tech Discussion 2 June 27th, 2009 11:55
Which manifold gasket? joshv98xj Modified Tech Discussion 2 October 23rd, 2007 17:03
exhaust manifold gasket - 99 vs. 91-98 jkmhb OEM Tech Discussion 1 June 4th, 2004 09:56
1999 manifold gasket jkmhb OEM Tech Discussion 1 April 7th, 2004 14:48
