Old December 13th, 2011, 18:51
aquickmopar's Avatar
aquickmopar aquickmopar is offline
Re: Everything you ever wanted to know about the AW4
Would still like to get rid of the manual and swap in the AW4.
Old December 13th, 2011, 18:53
cruiser54's Avatar
cruiser54 cruiser54 is offline
That doesn't mean there's not a problem with it. Sure you got all the air out of the system when you replaced the cylinders?
Old December 13th, 2011, 18:56
oldcancer's Avatar
oldcancer oldcancer is offline
well i'm at a loss then, i'm surely no transmission guy
on a random note though, i'm not exactly sure how to describe it, but i'll be driving and then come to a stop, and then it feels like a part of the drivetrain keeps spinning for a split second and then slams into another and stops it from spinning?
perhaps i'm due for a rebuild relatively soon? u-joints seem to be fine, no slack in em
perhaps i should look at the slip yoke coming out of the transfer case to see if it's all ground up in there or something?
AW4/NP231 combo, no SYE
Old December 13th, 2011, 18:57
Pumped and pumped and pumped until no air bubbles what so ever I did that for 4 days just to make sure. Still no air bubbles. Unless there's air trapped somewhere and wont come out.
Old December 13th, 2011, 18:58
oldcancer's Avatar
i believe there's a bleeder valve type spot down near the slave cylinder, same idea as if you were to bleed brakes, the whole "hold and pump" deal
Old December 13th, 2011, 19:02
Nope. Directions that came with slave cylinder said to hold slave cylinder with piston facing the ground and hydraulic line up toward bottom of vehicle and pump piston in and out, in and out repeatedly until all air is out of line. There is no bleeder screw anywhere. I've checked cause I thought it was odd that there wasn't.
Old December 13th, 2011, 19:04
oldcancer's Avatar
perhaps the YJ i did has a different trans then you do LOL, but i tried
Old December 13th, 2011, 19:06
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
If you're not looking for full automatic operation, swapping in the AW4 can be much simpler. What I'd do -
pull the AW4, NP231, rear shaft, front shaft, and any other parts you'll need from your donor. It's a 21 spline AW4 so not ideal and will limit your spare parts availability, but that can be handled.
Another thing I just remembered - you're going to need a 91-01 flexplate, since the flexplate from the 89 is for the RENIX CPS + ECU and won't line up electronically with an OBD CPS + ECU. If you were closer/I had more time I would mail you one, I have AT LEAST two or three decent ones sitting around.
Pull your AX15, swap in the AW4. If you care about your reverse lights you can get them working again using the proper pins from the NSS to drive the wiring that used to be hooked to the reverse switch. Swap in the older case with the SYE, the driveshafts, etc as well... you may have to shorten or lengthen the rear but I think the front should line up.
You have 3 wires that are important on the AW4 - the solenoid ones. If you don't mind always shifting in manumatic mode, you can wire them to the NSS and some toggle switches or a rotary switch in such a way that it'll work fine, you just need to know to shift it manually. I'm not sure exactly how to wire it up to the NSS but can look into it sometime tomorrow or Thursday hopefully. If you don't mind having to use the AW4 shifter as well as a rotary switch to shift, you can do it very simply with a 2 pole 4 position (or 6 position, radio shack has a 2 pole 6 position rotary in stock that works great) rotary switch.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
No prob thanx anyway, Besides id much rather swap in the AW4.
Old December 13th, 2011, 19:17
oldcancer's Avatar
theoretically speaking, would it be possible to use an aftermarket shift lever that has an extra slot in it?
for example, as opposed to haveing 1-2/3/d it would have 1/2/3/d instead?
and then you'd be able to use the shift lever for all 4 gears?
Old December 13th, 2011, 19:18
My last post was toward oldcancer.
Now on to your last post Kastein, and thanx for all the advice and info, very helpful. I was looking into buying RADesigns baja shifter and going that route encase the wiring of th TCU was a pain.
Old December 13th, 2011, 19:21
Yes I believe you can check out this company, link provided below.
http://radesignsproducts.com/14Shiftcontrollers.aspx
Old December 13th, 2011, 19:25
oldcancer's Avatar
interesting, it looks like it would even fit in the factory center console, and if not.....well that's why they invented the sawzall
Old December 13th, 2011, 20:29
kastein's Avatar
that would work great, actually. RADesigns is a sponsor here and their stuff is designed to work with that trans.
You need to keep both shifters IIRC - the factory shifter is mechanical and controls the valvebody hydraulically, while the RADesigns one is electronic. The only difference I believe is that in the mechanical 1-2 shifter position, the overrunning clutches are locked, resulting in much stronger engine braking. I'm not sure if you can enable that electronically but I haven't found a way to do so, I need to look through teh valve body diagrams in my FSM a bit more. Also the torque converter lockup solenoid is not controlled by the RADesigns shifter (iirc, could be wrong) but you really only want to run that with a toggle switch anyways, and probably only in 3rd/OD.
Old December 14th, 2011, 00:12
oldcancer's Avatar
funny how he found that too, cause after i posted, i thought of how little sense it would make to have a shift lever with 4 drive gear positions while the transmission would still only have 3 selections anyways due to the linkage, but then again, i had never considered 2 shift levers
Wanted Phil Sierra Chapter For Sale 2 October 21st, 2008 09:58
Wanted: XJ MrWonderful NAC Classifieds 7 October 5th, 2006 16:31
WANTED-ECM 90MJ242 NAC Classifieds 5 September 23rd, 2006 13:26
98-99 HP D30 wanted Talyn Wanted: Private Party Only 1 July 14th, 2004 21:57
