Old January 12th, 2021, 13:16
gmcchamp99 gmcchamp99 is offline
1996 XJ 4.0 better alternator?
I've been doing a bit of research for a while now on getting a better alternator in my two XJ's. With a small Amp, blower motor and or headlights on the voltage dips below 13.0v and it just doesn't sit right with me. I experimented with a 120amp from a 96 grand cherokee and the fit seemed just fine. I didn't have to modify the bracket or anything. Wiring was the same as well. The pulley was a bit bigger in diameter but I just adjusted adjusted tensioner and it was golden.. Anyone have any input? It's been a few days and I've been checking the wiring and such just to take sure it's not getting hot or going to melt anything and it seems to be doing fine. The voltage gauge stays over the 14 line now which keeps me and the battery happy.
Old January 12th, 2021, 13:24
Agreen Agreen is offline
Re: 1996 XJ 4.0 better alternator?
Next thing you should do is change your battery, starter, and alternator cables. It's not as hard as it sounds. I used a razor knife and cut back the loom until I got the cables out, then took them to Oreilly and approximated the correct sizes, then bolted the new ones in. Not surprisingly, the original (or one that I got with this jeep) woke up and charging has never been better.
Old January 12th, 2021, 13:34
I should have mentioned I did that previously before the alternator and battery swap. The cables had all seen better days so I started with that and then upgraded to a 35 series Optima Red Top.
Old January 12th, 2021, 13:35
I seen the Mean Green alternator and just didn't want to spend $300+ on it.
Old January 13th, 2021, 05:15
75SV1 75SV1 is offline
There is the 136 amp from the ZJ. I did install one into my '98 XJ. Need to remove some aluminum from the bracket though. Also, might check into upgrading the fusible link. I plan to upgrade to a 4ga wire and a MEGA fuse. Others have done that. There is also a 160 amp from the 03 Dakota. I am looking into that, for a '01 XJ. Different plugs. I think they can be converted to the older style.
Old January 13th, 2021, 17:33
Good to know 75SV1, thanks for letting me know. I figured it would fit but didn't want to assume and end up melting wiring.
Old January 14th, 2021, 05:51
I have run the 136 amp for a few years, with no problem. Still, I would plan to upgrade. The other side is the factory fuse link will not flow as much as an upgraded one. So, while you have upgraded the alternator, you are not getting the full benefit.
LED Alternator Light with PCM Controlled Alternator??? ROKRWLR Modified Tech Discussion 0 March 25th, 2015 08:43
Different alternator brackets for different years/alternator upgrades for a 2000? krakhedd Modified Tech Discussion 6 February 15th, 2014 11:53
WJ 4.0 Alternator Bracket - Relocate the Alternator on Your XJ freerider15 For Sale: Private Party Only. XJ ITEMS ONLY 5 July 29th, 2013 19:31
I upgraded my alternator to the 136a alternator from a ZJ whats next? Demolition_x Modified Tech Discussion 16 July 22nd, 2011 10:18
Alternator Relocation / Alternator Upgrade Jamescad04 Modified Tech Discussion 6 April 1st, 2011 21:21
