OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
NP231 front output yoke swap.
I'm trying to find some answers for my np231j front output yoke on my 89 xj. My jeep originally had a np242j in it and i swapped to the np231j. I went to hook up my front driveshaft and noticed that the front output on my 231 had used a strap for attaching the original driveshaft to it and my driveshaft uses bolts. Is there anyway to swap the front yoke to the correct one for my driveshaft? If so could someone help me find the correct yoke for my tcase and driveshaft?
#2
Re: NP231 front output yoke swap.
Going out on a limb here, definitely not something I've run into myself, but it sounds like you have 231 out of a YJ, which would have a yoke like
https://www.quadratec.com/products/52239_00.htm and you need a yoke like https://www.quadratec.com/products/52239_0002.htm |
#3
I may be wrong here, but I've seen a popular thing to do is to convert the bolts to straps by drilling the yoke out. For you it would be far easier since it's already set up that way and you don't have to swap the yoke.
#4
That does not apply to the transfer case since it uses a double cardon joint.
#5
Doesn't fit?
#6
Doesn't "work", cv yokes are different than u-joint yokes as they don't use straps/bolts or u-bolts. They are threaded for a straight 5/16" bolt.
OP, you can purchase a new one easily but if you have any issues I have a spare one. |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Np 231 front output yoke differences? | outlander | OEM Tech Discussion | 2 | October 29th, 2016 20:30 |
np 231 front output yoke to use as dana 30 yoke? | rockwerks | Modified Tech Discussion | 11 | May 3rd, 2007 15:51 |
242 front output yoke | xj-grin | Wanted: Private Party Only | 2 | January 24th, 2005 09:07 |
what size is the front output yoke nut on np231? | orvpark | Modified Tech Discussion | 2 | January 15th, 2005 09:10 |
NP 242 front output yoke | sidriptide | OEM Tech Discussion | 0 | July 13th, 2004 21:17 |
