    More Information - Join/Renew
1991 Jeep XJ weird buzzer problem.
Biggie Z
Hello everyone, I'm having a weird electrical problem with my jeep. When I turn the steering wheel all the way to the right, the ignition buzzer and interior lights turn on. It only happens when turning to the right, not the left. Does anyone know what the problem might be? Also, I could could have sworn that the front blinkers used to alternate between the side marker and the the light right below the headlight but now they both blink at once. Any help is appreciated, thank you.
I would be logical to suspect that there is an issue with the steering column wire harness, or the turn signal switch assembly.
