Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Grand Cherokee > ZJ and WJ Grand Cherokees (1993 - 2004)
ZJ and WJ Grand Cherokees (1993 - 2004) Technical forum for the classic ZJ and WJ Grand Cherokees.
Old October 11th, 2019, 19:43
Jaime01 Jaime01 is offline
Do I have a vari-lok
Hello,
I have a 2002 4.0 wj and need to replace the half shafts. Rock auto is asking with or without vari-lok. Can anybody educate me on how to tell if I do donít have one.
Thanks in advance
Old October 12th, 2019, 22:36
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
Re: Do I have a vari-lok
If you have quadra drive you have it. If not not the you don't. Since it's a 4.0 doubtful. What tcase do you have?
88 MJ, 4.0, 4wd, 3 pedals, Shortbed.
Mods; ACOS, quick discos, HD tie rod and a bitchin air fresher
04 WJ, 4.7HO
Mods; 3" IRO lift, ADDCO rear sway bar, 4.7HO with bored fastman TB, AFE intake and Superchip tuner, 32s, lunchbox rear 242HD, 3" Kolak exhaust
Old October 16th, 2019, 14:53
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
"If you have Quadra Drive you have it.'
The various transferases used in WJs.
http://wjjeeps.com/tcases
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old October 20th, 2019, 19:50
It appears that I have a selec-trac and I understand that to mean non vari-lok.
Thank you for your responses good information.
Vari-Lok Progressive Differentals???? Hillbilly XJ Tow Rigs and Trailers 27 March 16th, 2014 21:50
Leupold Vari-X II 3-9x50mm for TRADE, need wheels/tires... SuperSport88XJ Non-Jeeps Items go here. 0 April 30th, 2007 12:21
vari lok or hydra lok torfinn Modified Tech Discussion 6 January 24th, 2004 23:34
