Old November 15th, 2019, 15:11
lawsoncl lawsoncl is offline
Can't find Mopar Crankshaft Position Sensor
I can't find a Mopar one. The dealer says they are discontinued and they just get theirs from Napa. Who made Mopar? What brand would you suggest as they all look like they came from China most have lots of bad reviews. Omix-Ada?
My symptoms. 1989 MJ cranks and spins, but no fire. Confirmed the fuel pump is running by measuring voltage across the fuel ballast resistor at key-on, but not while cranking, and timing light shows I've got no spark. Unplug the CPS, measures 200-ohms, plug it back in and she fires right up. I haven't scoped it yet to see what it looks like. Wiring looks good, but I don't have a spare CPS if/when it dies again.
Old November 15th, 2019, 16:32
EvaB99XJ EvaB99XJ is offline
Re: Can't find Mopar Crankshaft Position Sensor
I found some genuine mopar CPS's on ebay and on summit racing and several other places.
Google "1989 jeep comanchee crankshaft position sensor oem"
They do seem to be drying up....
Old November 15th, 2019, 16:38
BALTANAKT BALTANAKT is offline
The CPS situation is getting dire. I bought one from NAPA for my '91 and it didn't work at all.
Old November 15th, 2019, 17:36
tech1001 tech1001 is offline
I used one from autozone that worked , I did buy a OEM crank sensor but still have not put it in the autozone one is 3 years old now .
Old November 16th, 2019, 07:10
CJR CJR is offline
I've been buying my CPS from NAPA and they work just fine with Cruiser's hole mod to get them closer to the flywheel teeth. Likewise, I file notches in the two(2) CPS holes so that the next CPS change goes easier; i.e. just loosen the two(2) CPS bolts (don't remove bolts) and then slide out the old CPS and slide in the new CPS and tighten the bolts. IIRC, the American mfg. "Wells" makes the CPS.
Best regards,
CJR
Old November 16th, 2019, 07:34
Ralph77 Ralph77 is offline
Best regards,
CJR
Good to know. So I went to their site and looked up for a '89 Comanche with a 4.0. Apparently 2.
With High Altitude Emissions SU3014
https://www.ebay.com/p/75285457?iid=...kaAldkEALw_wcB
Without High Altitude Emissions SU3228
https://www.ebay.com/itm/Engine-Cran...wAAOSwMZFbmyco
Old November 16th, 2019, 07:47
Forgot the link to their website:
https://wellsve.com/parts/
Old November 16th, 2019, 08:39
I suspect there are only a few actual Chinese manufacturers and everyone is just relabeling them. I'd prefer new-old-stock mopar if I can find one, but it looks like most of the webite claiming oem aren't actually selling oem. I plan to do the hole/slot mod, and maybe the high-altitude timing mod if I grab a cheap one that I don't mind breaking.
Old November 16th, 2019, 10:08
CJR CJR is offline
If you can't find a High Altitude CPS, a standard CPS can be simply modified, as per Cruiser's instructions, to be a High Altitude CPS.
Best regards,
CJR
Old December 15th, 2019, 11:14
TrialLake's Avatar
TrialLake TrialLake is offline
Go to summit or napa for your crank sensor. No matter which, you will be replacing your crank sensor again and again because it's a Jeep thing (: You should always carry a spare. FYI crank sensor makes it look like you're getting no fuel, bad battery, no spark, no oil pressure etc etc etc... ALL of this shuts down temporarily (one day permanently) then miraculously it all works again for a few miles then down again until you replace the crank sensor. By disengaging it then engaging it and it starts, you're doing exactly the same thing it does when it shuts you down then sits for a few then starts again. And, crank sensors almost always go down alongside throttle sensor, save yourself the misery and just replace both then do it regularly.. after almost getting in a wreck because of it, I change them like I change my oil.
can't find OEM crankshaft position sensor littleredxj0608 OEM Tech Discussion 2 November 6th, 2017 16:02
Where to buy a Mopar Crankshaft Position Sensor online? bmpweXJ OEM Tech Discussion 13 May 6th, 2016 04:56
Crankshaft Position Sensor k.smith904 OEM Tech Discussion 28 October 25th, 2008 21:28
Crankshaft position sensor 95 vs 97 crawll OEM Tech Discussion 1 February 9th, 2008 11:53
Crankshaft Position Sensor on '88 LuckysHunter OEM Tech Discussion 11 April 11th, 2006 14:20
