Go Back   NAXJA Forums -::- North American XJ Association > Support and Administration Forum > User Support, Questions and Suggestions
User Support, Questions and Suggestions Not Jeep Tech Questions. Forum use related questions or comments only.
Old July 11th, 2014, 17:19
Nimrod's Avatar
Nimrod Nimrod is offline
Degenerate Jeeper
How do you change the text that appears under your use name?
To the right of a member's avatar, under the user name, there's a short bit of text that by default reads, " member." On the User CP page there are options to add or change the avatar or add or change a signature, but I can't figure out how to change " member" to something more witty. Step 1: think of something witty. Step 2: ?
Old July 12th, 2014, 08:40
hawkeye 1 hawkeye 1 is offline
Re: How do you change the text that appears under your use name?
Go to your profile, on the left click on edit your profile. In the second frame go to"Optional Information, change user title. Hope this helps.
Old July 12th, 2014, 12:53
Nimrod's Avatar
Degenerate Jeeper
My profile page looks like this:
I don't see the "edit profile" or "optional information" prompts. Am I on the right screen?
Old July 12th, 2014, 13:20
Nimrod's Avatar
Degenerate Jeeper
Don't see those prompts on this screen either:
Old July 13th, 2014, 07:20
MT Mike's Avatar
MT Mike MT Mike is offline
Click on the "edit your details" tab. Midway down the screen is a text block called "Custom User Title". Type in what you want, scroll to the bottom, and click save changes. Done.
Old July 13th, 2014, 07:33
Nimrod's Avatar
Degenerate Jeeper
Geez. It seems so obvious now.
Thanks guys.
Old July 13th, 2014, 07:34
Nimrod's Avatar
Degenerate Jeeper
Now to think of something witty.
Old April 25th, 2022, 15:26
Bent's Avatar
Bent Bent is offline
Stuck In a Rut
Still thinking on it?
DEFY LIBERALISM
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 Stock-ish
- SoCal Chapter President -
Rate This Thread:
Leaking what appears to be tranny fluid robhurlburt OEM Tech Discussion 7 June 28th, 2011 10:18
Rear Differential appears to be leaking Mastodon OEM Tech Discussion 9 May 19th, 2011 08:13
Lower CA question, im on the edge it appears. Fixn2xlr8 Modified Tech Discussion 5 February 6th, 2011 12:44
'91 HO appears to be fuel flooding..... YELLAHEEP OEM Tech Discussion 6 January 11th, 2009 15:31
A warning appears Boatwrench User Support, Questions and Suggestions 3 April 19th, 2006 22:19
