Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Non-Tech / Off Topic
Non-Tech / Off Topic The popular Non-Tech Forum. NO SPAM at all. Period.
Old July 19th, 2022, 17:28
Anak's Avatar
Anak Anak is offline
Stranger
Blankety-blank Cheap Parts!!
Last fall I went through a bunch of maintenance on my Cummins to get it in shape for another season of towing. Among the things I did was take care of some old vacuum lines and fittings, especially en route between the vacuum pump and the brake booster diaphragm. Well, today I try to pull into a parking spot and discover my brake pedal is hard as can be and I am getting virtually no braking for my effort. Nearly hit another car.
This was the culprit:
That fitting was new last October. That fitting was also a pain to find. I well remember the challenge. The parts clerk at Napa was of no use whatsoever. I wound up settling for a part I could find on a rack at Vatozone. I wasn't settling for that today.
This time I went to Napa with a box of another, comparable, fitting in hopes that would provide a clue. I got lucky and got an old guy who knew what a book was and could actually look for parts (those types are few and far between anymore). He found me what I wanted. Well, at least as good as I could hope for:
The "2-668" fittings are ones I bought for my XJ's vacuum lines 5 years or more ago. Then too I had gotten lucky and found someone who knew how to look up parts. I bought the whole box and saved it knowing a day such as this would come again.
Here is the bummer though:
Country of origin makes a huge difference. The old ones (5+ years old) are still pliable. The new ones from China are hard as can be. I had to use a heat gun in order to get them installed. That does not bode well for the future.
I have no idea how to get anything better. The last time I succeeded in getting anything from the stealership it was a thermostat for my XJ, and they had to order that in. Virtually everything I ever try to get from them is long obsolete. Junkyard rubber parts are not anything to put hopes in.
If the Chinese don't kill us with their virus they will get us with garbage parts.
Old July 28th, 2022, 17:31
Bent's Avatar
Bent Bent is offline
Stuck In a Rut
Re: Blankety-blank Cheap Parts!!
Garbage parts built exactly to the specifications, and tolerances they were given. AutoZone, Home Depot, Lowes, etc, etc, etc.
"Do what you have to do to meet our price point."
DEFY LIBERALISM
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 Stock-ish
- SoCal Chapter President -
Old August 11th, 2022, 23:18
RickDT RickDT is offline
And they have invaded most of our stores!
Old August 27th, 2022, 13:11
Bent's Avatar
Stuck In a Rut
Originally Posted by RickDT View Post
And they have invited by most of our stores!
FIFY
I agree, though. The best I can do is shop name brands.
DEFY LIBERALISM
Rate This Thread:
heading to the bone yard for some cheap lift parts... cheap lift check list? ericfx1984 Modified Tech Discussion 7 January 17th, 2011 15:38
-Cheap Stock 01 XJ Parts - NP231 Parts, Rear Driveshaft, T Case Drop yamaholic MWC For Sale/Wanted Forum 1 March 20th, 2010 19:40
Blank, Blank, Blankety, Blank Fred Colorado Chapter 1 June 22nd, 2009 08:52
blank key question 87baseomatic OEM Tech Discussion 2 April 9th, 2007 17:57
Ignition key blank for an '88 RTicUL8 Wanted: Private Party Only 1 September 6th, 2004 12:38
