Front Axle Twist When Braking In Reverse
rokclimbertx
NAXJA Member #1267
Gainesville, TX
ok... trying to get a diagnosis... searching has added worn shocks to this list, upper and/or lower control arm bushings worn, worn tie-rod ends...
here's what's happening... backing up at slow speeds (say out of a parking space) then applying the brakes causes the front axle to twist bottom forward... moving forward and braking is normal... also, when this twist occurs it seems like the brake cylinder is banging onto the rotor...
i know i have a worn bottom bushing on one front shock, can't get the lower control arms to move by hand... i'm at work and can't crawl under to get a good grip on the uppers... tie rod ends look good to me & a guy here (but there's a lot of miles on them)... new rotors & pads maybe 5 or 6 months ago...
2001 XJ, 230,000+ miles...
Unless I am reading something wrong you are going to need the Jeep on at least jack stands to make a definitive diagnosis. The control arms need to be stress free to check the wear/ deterioration of the bushings. I think it would be easier on a lift, but jack stands will do OK too.
shocks wont affect the movment of the axle. tie rod ends wont affect rotation of axle as you described. The only thing that will affect the rotor/ caliper relation is the unit bearing. if the axle beam is rotating, it is your control arm/ bushings/bolts/ or brackets. If just the knuckle is rotating, it could be badly worn ball joint
had the same EXACT problem. replaced both LCA bolts on the frame side, cranked as tight as i could and haven't heard a peep since. the longer it goes without being fixed, the worse it'll get as the bolts start to ovall out the holes...
