Googenheimer
- Provo, UT
First off what does the Idle Speed Stepper Motor do anyhow? How does it regulate the idle speed?
My '88 4.0 is having a tough time idling and accelerating. I took it out last night and when I went to pull out from the driveway the Jeep seemed real sluggish and then it got over it and started to run smooth for about 5 seconds but as soon as I added a little throttle it bogged down again. I had to barely touch the throttle to get it to go. I stopped in a gas station to take a look under the hood. I pulled out my air filter because it seemed like the engine was gasping for air. The air filter was dirty but not the cause of the gasping sound. The engine would run rough for about thirty seconds and make this sucking chest wound sound and then the sound would stop and the engine would run smooth for five seconds and then repeat over and over. It sounded to me that the engine was choking itself to death. I revved the engine a bit and that almost caused a backfire through the air box. It seems like it is getting too much fuel and not enough air. What controls the amount of air going into the manifold. Would that be the MAP sensor? Which one of these is the culprit or is it something else? Any help would be much appreciated.
