Old January 2nd, 2009, 12:04
walkerja191 walkerja191 is offline
Why is my gas mileage so bad
I have a '94 Cherokee sport 4.0 with a 4 inch lift. I have tiny tires on it right now for the winter and I am only getting 13 mpg. Does anyone have any idea what could cause this?
Old January 2nd, 2009, 13:09
90Pioneer 90Pioneer is offline
Re: Why is my gas mileage so bad
I would say you're damn lucky.
My 96 XJ, when stock, would only get 12MPG no matter what I did!!
Now heavily modified and weighted down w/ lots of steel, it gets 10mpg.
Old January 2nd, 2009, 13:17
MnGrnXJ's Avatar
MnGrnXJ MnGrnXJ is offline
Thats some crappy gas mileage... Check your air filter, plugs, wires and coil. I just did a tune up on my 96 XJ and replaced all of 'em and I am getting 20 on the highway and 17 in city. Of course my Jeep is totally stock at the moment so that prolly makes a bit of a difference.
oh yea, when was the last time you changed your o2 sensors?
Old January 2nd, 2009, 14:13
igotanxj igotanxj is offline
X2
My 96 gets 20mpg on the highway with 2" boost and 29s. Check all the above mentioned stuff expecially your upstream O2. If it's original- replace it. A lifted XJ will get worse mileage, but I don't think it should get that bad. Also, what is "tiny" tires?
Old January 2nd, 2009, 15:37
winterbeater's Avatar
winterbeater winterbeater is offline
13 MPG on short trips around town in the winter and warming it up a little would be totally normal.
Old January 2nd, 2009, 15:43
Thats true, if you do a lot of around town driving, and lots of short trips where the engine is basically just trying to warm up the whole time, then 13mpg would be normal. Highway is a different story tho.
Old January 2nd, 2009, 16:17
Just tested my stock 2000. Slightly disapointed at 18 MPG at sustained (3 hour) 80MPH drive. I expected about 20. I did have a 5 or 10 minute warm-up included in that though, but I think that's just an excuse. This vehicle is new to me and I probably need to test the O2 sensors. Should bad O2's show up with a code reader?
Old January 2nd, 2009, 16:20
Jeepm@n Jeepm@n is offline
I just read in OEM tech that a gentleman had a loose connection on his temp sensor causing his Jeep to stay in open loop mode. Not allowing the engine to use the O2 sensor to adjust air fuel ratio. My 96 and my 94 average around 17-18 in the winter months. All backroads and 30% 4wd use.
Old January 2nd, 2009, 16:34
badandy's Avatar
badandy badandy is offline
I've noticed a drop in fuel mileage in all three of my vehicles, '07 Buick Terraza, '06 Chevy Van1500, and '92 XJ
Here in Florida it's been attributed to E-10 being added at the pump:
http://www.floridajeepers.net/viewto...hlight=ethanol
If you read through the entire thread some have noticed as much as 23% loss in power as well as a loss in mpg!
Old January 2nd, 2009, 16:39
I would say that's because of the 80mph speed. Slow down to 60-65mph (i know, it sucks) and you'll get your fuel economy back. XJ's have the aerodynamics of a brick. If your O2 sensors were bad you'd be getting closer to 10-13mpg. Usually, they don't show up with a code, but if you can read live data, a bad O2 sensor might read lean.
Old January 2nd, 2009, 17:07
xcm xcm is offline
i dunno about HO's, but on a renix, a missing, or wrong thermostat will have the same effect. if you havent been into the cooling system, this is a high probability on 15+ year old cars bought for cheap. i have found at least 3 xj's were missing the tstat while working on them.
when was last tune-up?.
o2 change?
cat-change? could be plugged
Old January 2nd, 2009, 23:29
Monkey55 Monkey55 is offline
I agree.
18mpg at 80mph is pretty good..
winter - no need to test the O2 sensor based on the mpg at that speed.
E
Old January 3rd, 2009, 03:30
Hammered's Avatar
Hammered Hammered is offline
keep in mind youre driving cinder block on wheels. Heres what I got, not sure if you want to throw money at this stuff.
http://www.performancedistributors.com/jeep.htm
Old January 3rd, 2009, 12:23
Mtb Jak's Avatar
Mtb Jak Mtb Jak is offline
winter gas effects it too..
Old January 3rd, 2009, 13:02
time2getdirty's Avatar
time2getdirty time2getdirty is offline
my cats breath smells
i have a 98 with 5" of lift 31" tires 4:10 gears and im getting 21 mpg!
Gas mileage? bigboyslimjimbo Modified Tech Discussion 20 October 30th, 2008 07:43
better gas mileage shimmy Jeep Street and Performance 33 October 30th, 2006 13:33
mileage DansGreyMj OEM Tech Discussion 1 June 19th, 2006 00:49
bad gas mileage.... rsliman OEM Tech Discussion 7 June 14th, 2006 06:22
Mileage Gnat5680 Non-Tech / Off Topic 19 May 14th, 2006 17:58
