Old November 21st, 2007, 07:01
icebergmedic icebergmedic is offline
Exclamation Better mileage
Hey all!
New to this site. I've got a stock, (at the moment) 88 4.0 that is getting rotten fuel mileage. I've tuned it up, (plugs, cap, rotor, wires) ran a good fuel injector cleaner thru the tank, sprayed down throtle body with carb cleaner and ran a couple of tanks of Ethanol blended gas.
What can I do for "bolt on" performance and economy? Let me know what works... Cold Air intake, exhaust etc.
Thank you,
Wally
Mission, British Columbia Canada
Old November 21st, 2007, 07:20
MudDawg's Avatar
MudDawg MudDawg is offline
NAXJA Member #728
Re: Better mileage
Gearing?, tire size?, trans type?
Old November 21st, 2007, 07:21
JNickel101's Avatar
JNickel101 JNickel101 is offline
Re: Better mileage
How "rotten" is your rotten fuel mileage?
Old November 21st, 2007, 07:50
JACKED COUNTRY JACKED COUNTRY is offline
Re: Better mileage
i have been on the search for better milage for a while now.the two best things i did that improoved my milage and increased performance,were a jacobs ignition system and an ff dynamics triple thret electric fan kit,those two added over 50 miles per tank more and made a big difference in power that you can actually feel,my cherokee runs better then ever but i am still searching for more mpg,total cost for both was 400.00 on ebay and they already paid me back 3 fold.
dont bother with the headers,they did nothing for me,waste of money,i got a cold air intake,i makes the engine sound more powerful but i didnt feel anything when driving,i didnt gain any miles from that either.
Old November 21st, 2007, 08:04
JNickel101's Avatar
Re: Better mileage
FF Dynamics Triple Threat electric fan???? Got a link to that??
Old November 21st, 2007, 08:57
sjx40250's Avatar
sjx40250 sjx40250 is offline
Re: Better mileage
Welcome.
Your best friend on the topics you mentioned is the search tool. All of those topics have been covered several times.
Having said that, you should also check your vacuum lines for leaks, check you O2 sensor (search), manifold leaks (idle and spray around intake manifold joint with head using brake cleaner - change in RPM = Leak) and finally you should check the injectors for leaks. They are notorious for leaking between the metal and plastic. If they are original, they are due to be replaced (search again or go to five0motors.com).
Old November 21st, 2007, 12:23
97XJ2's Avatar
97XJ2 97XJ2 is offline
Re: Better mileage
What i find that works is I either dont drive it. or know that no matter how bad I think I'm doing I always know that the guys driving the fullsize fords, chevys, or dodges are doing a whole lot worse
WTB: 97+ LOW MILEAGE XJ in SE ZachMan Wanted: Private Party Only 0 November 20th, 2006 15:12
Mileage Gnat5680 Non-Tech / Off Topic 19 May 14th, 2006 17:58
Mileage of 2wd vs. 4wd BSD OEM Tech Discussion 18 May 7th, 2006 04:59
Where the gas mileage go? balor OEM Tech Discussion 5 November 2nd, 2005 16:07
yay for gas mileage!!! DDCxj Non-Tech / Off Topic 8 June 30th, 2004 13:05
