Old September 24th, 2019, 11:59
paulhead's Avatar
paulhead paulhead is offline
I overtighten $#!t
Re: Bad gas mileage 10-11 MPG
Originally Posted by 4x4JeePmaNthINg View Post
Could a bad temperature sensor be a possibility? Just spit balling.
secondary to the temp sensor attached to the temp gauge?
“Lead me, follow me, or get out of my way. ”
-Gen. George S. Patton Jr.
Back at step 1, bought a YJ, an XJ going under the knife....
Old September 24th, 2019, 12:04
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
No, that exact one, on the thermostat housing.
Also do you know if your spark plug gap is correct?
Old September 24th, 2019, 12:10
Originally Posted by ehall View Post
torque converter clutch not engaging will do it for sure, since without the clutch you are relying on hydraulics alone. if you feel like the trans is shifting weird I would probably start there.
check for fuel leaks / damp fuel lines (no kidding)
use the key trick to pull codes and see if anything there that didn't trip the CEL
are you running a 180 or 165 thermostat? the computer tries to get the engine temp to 195 by running a rich mixture so that the cat converter works efficiently, if temp stays low the computer will forever be dumping unnecessary fuel. O2 sensor can do it too but not usually that aggressive
Pretty much ties into this, if its crapped out.
Old September 24th, 2019, 12:12
paulhead's Avatar
I overtighten $#!t
Last year after buying the jeep it passed smog with flying colors because the previous owner spent a ton of money on it including the intake system so it could pass and she could sell it so I assumed all that would be in order. So I'll put that on the list with exhaust manifold and vacuum leaks. I sprayed with brake cleaner for vacuum leaks but think I may buy one of those $40 smoke kits on ebay.
Old September 24th, 2019, 15:12
ehall's Avatar
ehall ehall is offline
It would cause the computer to dump fuel, same as running a lower thermostat
my '91 beater rebuild
Old September 24th, 2019, 15:29
paulhead's Avatar
I overtighten $#!t
Temps reading normal
Old October 2nd, 2019, 17:08
paulhead's Avatar
I overtighten $#!t
I don't know why I fight the easy stuff first. I assumed the plugs were good because it passed smog a year ago, my name is Dumass. I'll report a half tank later.
Old October 4th, 2019, 20:14
blu3fan's Avatar
blu3fan blu3fan is offline
I hate to tell you this.
but with the 35's and the lift. 10 mpg sounds right.
my stroker gets 8-12 city almost 20 highway. Im running 32's
Old October 5th, 2019, 07:40
paulhead's Avatar
I overtighten $#!t
My last XJ had the same exact set up and was a Renix and I got better mileage so I have to disagree with you.
Old October 5th, 2019, 10:03
jcnoble's Avatar
jcnoble jcnoble is offline
Is your speedometer/odometer reading correctly? Mine reads 10 mph high with 35 in tires and 4:56 gears.
88 XJ Renix Patina Color
4:56 Gears
35" Tires
Long Arm y-Link
Old October 5th, 2019, 10:13
paulhead's Avatar
I overtighten $#!t
yeah its dead on
Old October 9th, 2019, 09:25
90XJ_Seth's Avatar
90XJ_Seth 90XJ_Seth is offline
Originally Posted by cruiser54 View Post
Ever pulled the distributor cap and looked inside?
Don't use starting fluid to check for vacuum leaks. It can travel whereas carb cleaner and brake cleaner stay a liquid much longer.
A common issue is loose intake manifold bolts. Snug them up as needed.
The vacuum line from the intake manifold to MAP sensor is critical. any slight leak and the fuel mixture goes richer.
What would you be looking for inside the cap, let's say I had a similar issue with MPG.
Old October 9th, 2019, 11:08
paulhead's Avatar
I overtighten $#!t
Black chareded contacts. Pretty sure it was my plugs, gonna top it off here soon.
Old October 11th, 2019, 17:12
paulhead's Avatar
I overtighten $#!t
So after the plugs change 12.7mpg. Will report next tank full, and try to lighten my foot a little too.
Old October 15th, 2019, 14:43
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
Your temp gauge on a 96 and earlier uses a separate sender from the ECU, so that doesn't really rule anything out, unfortunately.
87-90 4.0: 3 temp sensors
- 1 in the left radiator end cap to turn the electric fan on (HD cooling option only)
- 1 in left side of block low down for the ECU
- 1 in the back left side of the head on the top for the gauge
91-96 4.0: 2 temp sensors
- 1 in the thermostat housing for the ECU, which now also controls the fan
97+ 4.0: 1 temp sensor. It's in the thermostat housing and the ECU controls the fan as well as sending the data to the instrument cluster
Honestly it sounds like you've gone through most stuff. If there is even a small crack in the exhaust manifold - very common at the 2 to 1 collector - it will suck in air in between exhaust pulses and this will cause the O2 sensor to read leaner than it should no matter how much fuel the ECU dumps in to compensate, because that air doesn't ever meet the extra fuel in any meaningful way until they both end up in the catalytic converter. I've seen an XJ get single digit fuel economy due to this problem and jump to 15-16 after it was fixed.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Why is my gas mileage so bad walkerja191 Modified Tech Discussion 33 January 6th, 2009 20:52
gas mileage mitsumotors Modified Tech Discussion 61 December 27th, 2007 19:33
Better mileage icebergmedic Modified Tech Discussion 6 November 21st, 2007 12:23
Where the gas mileage go? balor OEM Tech Discussion 5 November 2nd, 2005 16:07
No cat mileage ParkCityXJ Modified Tech Discussion 8 December 28th, 2004 23:10
