Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > South East Chapter
South East Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 84 votes, 5.00 average. Display Modes
  #16711
Old October 19th, 2019, 06:42
PacificEd's Avatar
PacificEd PacificEd is offline
Re: Weekend is over...what did you get done?
I guess. I’m not looking forward to putting a 3rd new radiator in the ZJ. I just don’t need that kind of stuff right now. It just isn’t something I enjoy doing. I like doing “fun” or quick upgrades etc.
Former SEC Chapter President: 2009-2012
Former National Recorder: 2013-2016
Old October 20th, 2019, 05:20
SlowXj SlowXj is offline
Rust holes are patched and the 8.8 perches are burned in. Anyone have issues using a front shaft in the rear with an 8.8, sye, and about 4.5 inches of lift?
Also does anyone know of a junkyard source of an 8.8 flange for a 1310 ujoint? All I seam to be finding is 1330..
Old October 20th, 2019, 06:13
PacificEd's Avatar
I used a front shaft in my 8.8 swap. I have a 4.0/AW4/NP231 w/sye. It fit with no issues.
The flange is found only on the first gen Ford Explorers 4x4 up to 1994. If itís a 2wd they are different.
Old October 20th, 2019, 16:26
Thanks Ed. That's my combo (4.0 aw4 231).
When I look up ujoints on rockauto it seems to think it's a 1330 joint. Not to be a pain but are you certain on the yoke year?
Old October 21st, 2019, 05:48
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
Got a glass guy coming over today to put a windshield in Annie. Fingers crossed that I got the passenger side A-pillar close enough to accomplish that. Last time he looked at it, he said I was about a half inch from it taking glass. I worked on it with the porta puller and I moved it to within 5* of the angle of the driver's side pillar. He said that the pillars in the XJ don't need to be perfect, so I'm hopeful.
Taking her to Land Between the Lakes on Saturday, and with a 40% chance of rain, a windshield would be a nice addition.
Dirk DeYoung--Member #176
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2006 XK (TOW RIG)
Old October 21st, 2019, 07:02
bosco01xj's Avatar
bosco01xj bosco01xj is offline
I got my tire carrier fabbed up over the weekend. I took inspiration from Detours Knucklebone. All that's left is to weld on the bolts for the tire and drill a couple more holes. It will be ready for this Saturday's trip to LBL.
Old October 21st, 2019, 10:58
PacificEd's Avatar
1991 to 1994 4x4 is what we pulled several out of. We pulled a 2wd one and something didn't look right.
Here is a like to the yoke you need:
https://www.northridge4x4.com/part/d...All%20Products
Old October 21st, 2019, 12:53
thechief86's Avatar
thechief86 thechief86 is offline
Pics. I wanna see!
Old October 22nd, 2019, 09:29
bosco01xj's Avatar
Originally Posted by thechief86 View Post
Pics. I wanna see!
Old October 27th, 2019, 19:01
Cottontail's Avatar
Three-De Off-Road
Looks good Brian. I got my welder out today and determined it worked. I bought it off a "for sale" forum in Brentwood for $20. A friend of mine has a son who is a welder so I FaceTime'd him and we worked through the machine. Need some parts for it, but once i get them I can start working on learning how to weld.
Old November 1st, 2019, 12:33
thechief86's Avatar
Closed on my new house, and in doing so got a decent garage to do gearhead stuff in. Will be moving in over the weekend.
Old November 3rd, 2019, 16:44
Cottontail's Avatar
Three-De Off-Road
Atta boy Eric. Where did you buy?
Old November 4th, 2019, 06:24
PacificEd's Avatar
I flushed two heater cores, one in a 1998 XJ and another in the 1998 ZJ. I then swapped out another radiator that was leaking at the tanks. I'm becoming a pro at this. I'm hoping that the 3rd times a charm.
After doing all that the dumb thing doesn't make any heat inside the Jeep. It blows outside temp to slightly warmer but never gets HOT. I burped the air from the heater core lines. The ZJ runs just under 210* with the 4.0L. Any ideas why it isn't warming up good?
Old November 4th, 2019, 08:31
techno1154's Avatar
techno1154 techno1154 is offline
I do not know anything about ZJ's but,...`does it have one of those vacuum control valves that need to open to allow the hot water to pass?
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old November 4th, 2019, 12:57
PacificEd's Avatar
I didn't see one. The lines come straight off the water pump and thermostat housing and go straight to the heater core lines. I was asked the same thing from another Jeep guy.
I need to get home and look at my Chrysler repair manual and just see what could be causing this. I pushed water both directions through the core before swapping out the radiator so I know it isn't plugged. Flow was good and consistent.
Rate This Thread:
What I did this weekend Starscream Modified Tech Discussion 27 January 6th, 2008 21:28
Took the weekend off.... jpbxj79 Colorado Chapter 3 July 24th, 2007 21:15
2nd Annual NAC Mohawk Madness Weekend Sept 3-5th labor day weekend sidriptide North Atlantic Chapter 77 September 19th, 2005 19:48
anybody going anywhere this weekend? MMIXJ Colorado Chapter 5 September 10th, 2004 14:19
