Old June 4th, 2019, 18:34
Lanser1999 Lanser1999 is offline
Ls swap into 2001 xj
Hello, I’m not sure if this is the right spot for it but I’m trying to get a list together for the basics that are required for an LS swap into an xj to help myself and everyone else looking to eventually do this swap. As far as is have found, it seems the easiest way to go is Novak motor mounts and exhaust, that I am willing to spend. With that being said I would like to keep the rest of the swap as simple and wallet friendly as possible. What transfer case is usually transferred in? Does it need an adapter plate? As far as the engine wiring goes do you use two harness in your jeep or merge the two into the ls harness? Are aftermarket gauges usually the way to go? Any other issues that will arrise please let me know because I am trying to educate myself on this swap.
Thanks
Old June 5th, 2019, 08:31
RCP Phx RCP Phx is offline
Re: Ls swap into 2001 xj
The transfer case is going to depend on what transmission your planning on using. You can get a trans adapter for the AW4. Do you have to deal with emissions?
Old June 5th, 2019, 08:52
ChrisOKF ChrisOKF is offline
Iíve been looking into this also since my 99xj motor just died on me. Found this YouTube series with a lot of answers your looking for.
https://youtu.be/ajakvK8PNQg
Old June 5th, 2019, 08:56
Episode three covers the transfer case
https://youtu.be/LIXx4JCMO5Q
Old June 5th, 2019, 15:29
I donít necessarily need emissions, depends on what route I go if I went LS (either 5.3 or 6.0) I would pair it to a 4l60e/4l80e, however if a different trans is doable and a lot less hassle I would go that route.
Old June 5th, 2019, 19:25
CheroZ28 CheroZ28 is offline
If your going emission's then you have to use the same trans that came with the donor vehicle. I did a LS1 swap and all emission's CA legal through a referee. I pulled all wiring from cherokee ecu and running only LS1 computer with new gauges. using 231 transfer case with adapter plate from novak too.
No emissions is heck of a lot easier but I didn't want to get a fat ticket for crossing a road with a green sticker. Motor and Trans came from a 2001 Camaro SS.
Old June 6th, 2019, 03:50
Is the 4l60e/4l80e swap hard or is it not bad as long as you keep the wiring harness/pcm/Tcm for the trans kept with the originally trans from the swap?
Old June 6th, 2019, 04:22
I also was thinking about pairing a 231c to the 4l60e and getting an SYE for the 231c? Is this the best option to retain the VSS on the transfer case?
the trans swap is pretty easy, just bolt it to the motor before you put it in the cherokee. If I have time after work today i'll take some pictures. just want to plan everything out first before you start.
Old June 6th, 2019, 07:19
I'm curious as to your objective, that's a lot of work and cost.
Old June 6th, 2019, 10:07
Iím just trying to figure out the easiest way to have a transfer case with vss, I currently have a 231j with an sye kit.
Old June 6th, 2019, 11:24
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
Get a Chevy 241C and install a JB Conversions SYE?
http://www.jbconversions.com/product..._j_std_sye.php
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old June 6th, 2019, 13:33
I assume you have the super short kit which is still easily adaptable to your current set-up.
Old June 6th, 2019, 15:10
I am not sure as to what SYE kit I have, it came with the jeep. However, wouldnít I need an SYE that has a spot for a vss or what is usually done as far as that?
Old June 6th, 2019, 16:24
the novak adapter that hooks transfer case to trans has the vss hole.
2001 Engine swap question MVU2ORC Modified Tech Discussion 13 October 15th, 2018 09:22
2001 XJ No start after Golen Swap BMXxXJ OEM Tech Discussion 16 September 19th, 2018 06:17
Swap '96 4WD Diffs and T-Case into 2001 2WD? seanof30306@yahoo. OEM Tech Discussion 3 December 9th, 2016 11:43
aw4 swap into 95 from 2001 oldguy63 Jeep Street and Performance 2 February 28th, 2012 18:00
2001 WJ 4.7 motor swap macgyvr Tow Rigs and Trailers 1 August 7th, 2011 21:59
