Prev Previous Post   Next Post Next
Old May 13th, 2019, 18:16
The Badness The Badness is offline
Another AC Clutch Issue
Hey guys, got a good one for you. 2001 Xj sport 4.0 4wd aw4.
Issue is the AC. I start her up, turn on the ac and for about 20-30 minutes, the compressor clutch stays engaged and the air is nice and cold. After that time frame the clutch disengages and reengages a couple times with a 5-10 second interval. Then i can hear the engine rev up a bit, as if it were to reengage the ac clutch...but this time, no engagement and the warm air starts to blow. So i get my handy paper clips out, and pull the plug to both the low pressure cut off and high pressure cut off, and jump them both for just long enough to confirm clutch engagement....again the engine revs up and i can feel the a/c clutch relay click, yet no clutch engagement. I whip out the tester, and there is no power to the ac clutch wire despite the ac clutch relay being engaged. Swapped relay...no change. swapped high and low cutoff with a working pair...no change. then to confirm clutch operation, i put 12v to the clutch wire and she engages...so the clutch is fine, the cut offs are fine, the relay is fine..is the a sensor elsewhere that determines power to clutch? Oh and shut her off and let her sit for a bit, and the AC goes back to normal for another 20-30 minutes. Stumped at this point
Clutch Issue hoopty1111 OEM Tech Discussion 0 March 12th, 2013 08:55
clutch issue wingnutooa South East Chapter 18 October 17th, 2011 15:28
Clutch Issue...need help andrew2516 OEM Tech Discussion 9 December 5th, 2008 09:03
AX-15 Clutch Issue. jeepman121 OEM Tech Discussion 16 May 7th, 2008 05:50
Clutch issue themangeraaad OEM Tech Discussion 4 June 2nd, 2007 12:12
