I just replaced my grill surround and upon replacing the headlight & blinker harnesses to their right spots I killed a blinker.
My driver's blinker does not work at all, the bulb is good. The passenger blinker works intermittently, works more than it doesn't work though.
If I switch the turn signal lever, the dash indicator stays lit OR don't come on at all.
My running light on the driver's side is also very sensitive, it'll go out, ,but come back on if I tap it.
Also, my dash lights are very dim as well, ,could this be tied into the blinker prob?
Those of you with dimming headlights, check the ground in the plug where the lamp plugs in, my ground is not great and the headlamp goes dim & bright if I wiggle it...any ideas on that fix too?
Thanks!
O yea, save the blinker fluid comments...heard em all already.
Thanks!
