Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > JeepSpeed, Prerunner and Competition Tech Forum
JeepSpeed, Prerunner and Competition Tech Forum For Discussion of Modications related to Prerunning, JeepSpeed, KOH, Rock Racing, and any other speed based competitions
Old January 18th, 2018, 19:12
The_Punisher The_Punisher is offline
Need advice setting up rear bump stops
Hi guys. Building a go fast XJ. Have a build thread, calling my rig Body Shot. Sucks now that photo bucket wants $$
I have these bumps on my fox shocks. Had experience with them on my JK. I was turned onto them by a cat on Pirate4x4. They work well. https://www.polyperformance.com/eiba...haft-bump-stop
I also have some sumo springs. They're designed to be used like air bags while towing and such. Metal Cloak sells them as bumps. I also had these on my JK and thought they were rad. https://www.supersprings.com/shop/ssr-402-40/
So I've got my rear 9" and deavers swapped under the jeep. I haven't mounted shocks yet. I'll be using the main leaf by itself to cycle the suspension in my garage with her on jack stands. This is when I'll setup shocks and bumps.
In theory, I want one bump stop to make contact first, compress maybe half-ish and then have the second bump begin to engage to create a nice progressive bottoming almost like hydro/air bumps.
The eibachs and Sumo springs are rated at 1000 lb rate at 50% compression. The sumo spring is 5" tall. So I guess 2.5" of "stroke" before it gets into the 1000 lb territory. The eibach bumps are 2.5" tall
The great thing about these, is like air bumps, they don't bounce you back off the bumps. It's pretty controlled.
I'm thinking maybe have the shock mounted bumps begin to contact just before the sumo springs contact the axle bump pads. Then as the 2.5" eibachs are compressed I'm working within that initial 2.5" of stroke of the sumo springs.
My goal is a nice progressive bottoming while using all of my travel.
Old April 22nd, 2021, 04:57
89Mock 89Mock is offline
Ever figure this out?
Old April 22nd, 2021, 06:44
NOTNSUV's Avatar
NOTNSUV NOTNSUV is offline
You Guys ROCK!
Re: Need advice setting up rear bump stops
Hmmm..
I'm a 'Do-it-Twice' kinda guy.. or..
Cross thread's better than 2 lock-washers
1999 XJ Sport 4.0L Black
Rate This Thread:
Rear bump stops N8N_99xj OEM Tech Discussion 9 April 2nd, 2017 12:08
rear bump stops? Alboy97XJ Sierra Chapter 15 January 7th, 2012 08:38
rear bump stops AZRockRunner Modified Tech Discussion 4 November 28th, 2006 11:16
rear bump stops afd516 Modified Tech Discussion 6 August 25th, 2005 03:34
MJ Rear bump stops tcm glx For Sale: Private Party Only. XJ ITEMS ONLY 3 January 23rd, 2005 22:28
