Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > North Atlantic Chapter
North Atlantic Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Old March 12th, 2009, 18:49
Justpunchit's Avatar
Justpunchit Justpunchit is offline
NAXJA Member #1291
Rebuild of my build...
Alright so I have a laundry list of things to do before NAC fest, for once I really want me jeep to be at 100% when I get out there it's just to far of a drive to leave anything up for chance. So I'm fixing any and all weak links I can or anything I feel isn't up to par. Today I got my RE 7.5 coils in and my winch came today so I had a few things to do. Also was looking at finishing up my wiring for my accessories and the 0 gauge cable swap.
All my goodies
This is the front before the new coils, as you can see I got spacers and the coils served there purpose but there old and I want a few more inches with just all coil instead.
Out with the old in the with new I love long arms just unbolt the shock and BLAM installed.
I did have to use a small spacer to get the exact new height I wanted but hey better than before. With the winch installed and extra bracing everything should level out mint.
For my bumper I'm still not 100% on what I'm going to do so it will adapt the winch but this is the idea I like the most and I'm gonna stick with it.
I'm going to cut into the bumper and then plate it.
I feel like it still will stick out pretty far what do you guys think?
anyways thats all the progress I made for tonight, this ain't know RCman build but I figured you guys will like it anyway.
Old March 12th, 2009, 19:07
RCman's Avatar
RCman RCman is offline
Life is big block
Re: Rebuild of my build...
Hey now, you can't compare your stuff to mine. Don't beat yourself up, it is a very nice XJ! You have a leg up on me being "road legal". I honestly hope you were just kidding.
http://i14.photobucket.com/albums/a3...s/IMG_0693.jpg
http://i14.photobucket.com/albums/a3...s/IMG_0691.jpg
After looking at your mounts, I'd say you need to add another bolt or two (sleeved in the unirail as cal mentioned). Then cut done into the bumper like you have marked out, but possibly a little more and then pushed back into the grill more. They winch is a relatively small profile (no huge integrated solenoid) so you should be able to tuck it in much further.
Also, while you are in there, get rid of those god awful towhooks and add some d-ring mounts that are tied in as far back as you can.
Old March 12th, 2009, 19:10
NAXJA Member #1291
haha yea I was kinda kidding, I wish I could tear into my jeep like yours, but it's true I can drive mine to work if I feel the need thanks for the compliment though. How far back should I be going with these mounts? Anything in mind?
Old March 12th, 2009, 19:15
RCman's Avatar
Life is big block
As far back as you possibly can. Personally on a winch bumper or anything that gets really used I'd like to see 7 or 8 bolts per side.
Check out these for inspiration.
Old March 12th, 2009, 19:25
NAXJA Member #1291
Wow I didn't think that it was really needed to have that many, I guess I underestimated the stress of a winch.
Old March 12th, 2009, 19:28
RCman's Avatar
Life is big block
Figure in how much force is really applied to those bolts and it'll really make you think...
You could probably get away with 4 or 5 large ones per side, but WHY risk it?
Old March 12th, 2009, 19:30
NAXJA Member #1291
Very very true.
Old March 12th, 2009, 20:12
Andy in Pa.'s Avatar
Andy in Pa. Andy in Pa. is offline
NAXJA Member #180
Yes, you should at least be tying in 4 to 5 additional bolts per side. Back in 2001 I modded a front Tomken bumper by welding on a winch plate. It worked well, but was only tied on with the factory 3 bolts. I ended up stitch welding it to the uniframe because it didn't matter how hard I tightened the hardware, I would STILL move the bumper when I was winching. After I welded it to the frame it stayed put. I even had to winch someone out of a trail once, dragging them sideways UP a rock face... and it held up well. I have since gone with a different style winch bumper (Rigid FTW!!!).
What material is your front bumper made out of? Wall thickness/ tube size, and whatever other info you have on it. Your design looks good, just make sure you extend the winch plate past the front of the bumper by a few inches so you can weld something on to mount the fairlead. Also, put at least 2 gussets under this extension so you don't bend it under heavy winching. As well, depending on the size of the bumper tube, you may want to find a way to tie it into the front crossmember, similar to how the Rigid front bumpers are tied in.
"I can get you in...."
Old March 12th, 2009, 21:34
xjbump xjbump is offline
Definitely make sure you have a good thick plate and its welded in there good. I saw a winch widen out the whole on a plate about a 1/2" before ripping off. It was 1/4" plate reinforced but wasnt enough.
Old March 15th, 2009, 14:24
NAXJA Member #1291
Wow, I never heard of that before.. I wonder if his bolts were tight....speaking of which is there a specific torque I should be setting the mounting bolts of the winch to? I made some more progress today, I used 1/4 plate for the actual mounting point to the bumper, and I sleeved it inside the square tube about 4 inches then welded it inside. I also took the time to try out the new torch set and make some D-ring tabs so I can get rid of those horrible hooks. This is the only pic I have now, I'll upload more later tonight. when I get a chance.
I still have to make some supports for the front of the plate and a few other small pieces to tie everything in... what do you guys think?
shitty side view
Old March 15th, 2009, 22:19
NAXJA Member #1291
I dunno if anyone actually is following this but this is what i actually cut into
Another pic I just thought looked fancy
Old March 15th, 2009, 22:37
scat's Avatar
scat scat is offline
I have not Confirmed, or I used a BAD email Addy
Bumper mods look good, I think you had mentioned that you were going to gusset the fair-lead mount, I'd consider putting gussets on the top side too.
Old March 15th, 2009, 22:39
NAXJA Member #1291
thanks, and yea I was thinking the same thing, I'll have to see what I can whip up tomorrow morning.
Old March 15th, 2009, 22:40
5spd_xj's Avatar
5spd_xj 5spd_xj is offline
<<the good ol days
nice job, looks good. tucked up nice n close, very nice
Old March 15th, 2009, 22:56
NAXJA Member #1291
It was doing great for being out of the way until that damn bulky roller fairlead had to come and ruin my parade..... >
Rate This Thread:
My XJ Rebuild Mtb Jak Modified Tech Discussion 39 April 27th, 2009 12:52
rebuild or buy used? FireFly SoCal Chapter 28 March 7th, 2009 00:06
rebuild eng+cam Greg'88 OEM Tech Discussion 0 June 6th, 2008 22:56
aw4 rebuild pb_beaker OEM Tech Discussion 18 May 10th, 2008 22:03
rebuild 800dollarjeep OEM Tech Discussion 2 October 6th, 2003 18:52
