1994 Jeep Cherokee Exocaged!!! ugly but very functional:)
tj00xj91
1994 Exocaged Jeep Cherokee
1994 Jeep Cherokee Sport 4x4
4.0l
AW4
np231
hp d30 spicer factory 4.56s 297x ujoints axles
29 spline 8.25 4.56s gears full detroit locker!!!
custom heavy duty dom steering
rustys hd trac bar and bracket
Drop down control arms brackets
Around 7-8" of lift
4.5 inch springs in back with 3 inch blocks
rancho 5000 shocks
borla header
flowmaster exhaust
15x10 mickey thompson wheels
35x15x15 tsls 50% or more tread, 1 wheel has a side wall puncture but holds air fine.
Jeep runs great, no known problems.
Nss doesnt work i have a push buttom to overide and start the jeep once the ignition has been turned to the run position.
Heavy duty bumpers front and rear, recievers front and rear
unibody has been reinforced in very many places
green exterior, tan interior.
has custom built half doors for the front, rear passenger doors have been removed and have bars welded for the exocage support and unibody support,
has the driver side rear window
missing the rear passenger side window and rear window
built in tool box were the rear seat used to be and a bus seat bolted down in the very back of the jeep
190-200k miles
$4500.
located in Tuscaloosa, Alabama 35401.
i might be able to help with delivery within reason
Again with this swingset?
At least you took some advice and painted that red cage black.
Only problem, with it red people in the oncoming lane could see it coming.
Gooooood luck.
:fuse:
