ptimhere
- new london, ohio
2001 Limited, with dual power seats.
The passenger side seat works, the driver side does not. If I understand what I'm reading correctly, they are controlled by a circuit breaker in the fuse panel. Is it possible that the breaker can work for one side and not the other?
Its definitely a power issue. If I run some patch leads to the driver seat, it will work. But with the standard power cable plugged in, it does not.
I would think that the power cable for the driver side doesn't have that much further to go. Without yanking carpet, I'm not sure where it would break.
