Swapping Command Trac to Select Trac???
As long as you get the right tcase (they vary in number of input splines and input shaft length... I forget what years the changes happened though) it should be pretty direct. Drive shaft length might change... but I dont think so. And shifter linkage might change, but I have no idea on that.
