OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
2001 2WD XJ Project
Picked up a decent 2001 2WD a couple years ago, seller said it needed a lifter replaced and included two (not 12??) with the deal. By the time it got paid for and ready to move, it wouldn't start. No fuel pressure at the rail schrader, I can hear the pump running. There is a small amount that comes out if you press the valve. I guess I need to drop the tank and replace the pump, regulator, filter. Any suggestions as to the best quality parts? I think I already have a Bosch pump, but the other parts will need sourced. ODO has only 125k on it, but given the door hinge wear and general condition, I'm not sure it's correct. Driver's rear door upper hinge has parted from the body. Are there reinforcement plates available for those?
#2
Re: 2001 2WD XJ Project
Fuel pumps are very year specific for the late years. Ive had great luck with the Delphi's. The odometer should be correct unless someone changed the entire cluster as the mileage is stored in the cluster.
Thread Tools | |
Display Modes | |
Parting out: 2001 XJ and 2001 WJ | JeepCherokeeGuy99 | SoCal For Sale | 7 | August 16th, 2015 09:05 |
MD: 99 XJ 4.0L project | Relwarc | NAC Classifieds | 0 | January 12th, 2015 12:41 |
2001 sport PROJECT | shortxjdoug | SEC For Sale / Wanted Forum | 3 | May 28th, 2014 15:45 |
Project 100$XJ and Project JEEPSPEED | AZXJ | Arizona Chapter | 23 | August 23rd, 2007 12:57 |
91 4dr project 33s, 91 4 dr project stock | Rockhound | For Sale: Private Party Only. XJ ITEMS ONLY | 1 | May 8th, 2007 20:13 |
