Old January 8th, 2019, 09:39
denverd1's Avatar
denverd1 denverd1 is offline
rebuilding front DS slip joint
think I found the source of my vibes. Front slip joint is beat down pretty bad. never seen any info on rebuilding these, have already done centering ball and the other joints are fairly new. Is this shaft toast?
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old January 8th, 2019, 10:02
RCP Phx RCP Phx is offline
Re: rebuilding front DS slip joint
Depends on what is worn? The slip yoke and/or the splines.
Old January 8th, 2019, 10:19
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
If worn excessively, the slip yoke would need to be replaced, and the drive shaft assembly rebalanced. Your local clutch and u-joint shop will be able to quote you for the job.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old January 8th, 2019, 11:28
denverd1's Avatar
slip joint in front shaft, I would guess it's beyond repair. will find local shop.
Chili Pepper '98
Old January 9th, 2019, 01:52
Jim Malcolm Jim Malcolm is offline
I spent more trying to fix my OEM shaft than I did on the top spec aftermarket shaft that I eventually replaced it with.
Old January 10th, 2019, 09:58
devildog0's Avatar
devildog0 devildog0 is offline
Just pop the coin on aTom Woods or an Adam's. I went Adam's and it was only a little more expensive than the expensive drive shaft on rock auto.
Sent from my SM-G892A using Tapatalk
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old January 10th, 2019, 11:21
denverd1's Avatar
what I'll probably do. would like to get some measurements from the D44 I'll be installing soon, current D30, factor in front axle stretch, figure out my final Tcase setup, etc.... so I don't have to this all twice. My rig being trail only, I'll probably just keep wheeling it as it is and keep some spare joints in my tool bag in case the vibes do more damage in the meantime.
may take it apart and see how beat down it is.
Chili Pepper '98
Old January 10th, 2019, 13:16
devildog0's Avatar
heck if it's trail only build a farm implement type drive shaft lol
Old January 10th, 2019, 15:07
denverd1's Avatar
with an 18" of slip joint! kinda like that idea. could weld my own yokes on it... actually trying to get back to street legal. local group has an obsession with backroads I guess you'd call it. It's not overlanding b/c they never get 50 miles from home, but cruise backroads and find somewhere to camp? IDK what they're doing honestly..
I'm more of a trailer it somewhere and get lost in the woods for a few days type of guy, but that's getting harder to find unless you go to CO or Ark.
good idea tho! I'll check it out. might be perfect for a temp setup.
Chili Pepper '98
slop in the front driveshaft slip joint ehall OEM Tech Discussion 1 May 14th, 2015 13:00
Length of front DS slip joint? veedubshafer Modified Tech Discussion 4 June 19th, 2009 05:04
Front DS Slip-Joint Sleeve BADaXJ OEM Tech Discussion 3 November 24th, 2008 06:14
Help rebuilding RE trackbar joint scott_m_c Modified Tech Discussion 7 July 21st, 2007 10:00
rebuilding fds d/c joint... mikeny59 OEM Tech Discussion 5 December 21st, 2005 15:02
