Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
transmission upgrade/issue
Hi guys,
Over the last few days I swapped in a Lower mile gearbox and while I was at it I installed a transgo shift kit SK 340. (probably not the best idea as the box wasn't tested unmodified) Situation I have now is I have reverse and no forward gears. I can hear the revs pick up a little when shifting into D but no drive at all. what do you guys think? the forums here in Australia are ver limited in their knowledge when it comes to transmissions. I'm planning on testing the solenoids first up.. Thanks a lot. its a bit of a worry.. |
#2
Re: transmission upgrade/issue
Unplug the tcu and put it in 1. Bypasees solenoid.
Sounds like a bad shift kit install though.
I'm not a complete idiot - there are parts missing. |
#3
Yep sounds like I’ve made a mistake somewhere along the install of the kit.
Does anyone have any resources on this kit? Or on the valve body for an aw4? Sent from my iPhone using Tapatalk |
#4
A little insight.....
https://naxja.org/forum/showthread.php?t=1147175 |
#5
Thanks a lot. Seems like a similar problem. I’ll make make sure to check the prv
Thread Tools | |
Display Modes | |
Transmission Issue | egiznad | OEM Tech Discussion | 3 | November 7th, 2015 21:25 |
transmission/transfercase upgrade? | 2stix | SoCal Chapter | 31 | January 20th, 2010 09:41 |
Transmission issue? Engine issue? | kastein | OEM Tech Discussion | 7 | September 9th, 2009 11:48 |
Transmission Upgrade | SUA SPONTE | Modified Tech Discussion | 11 | June 1st, 2007 07:52 |
Idling Issue After Injector Upgrade | XJVenom | Jeep Street and Performance | 7 | October 4th, 2006 17:57 |
