Old January 7th, 2019, 15:16
Futal87 Futal87 is offline
transmission upgrade/issue
Hi guys,
Over the last few days I swapped in a Lower mile gearbox and while I was at it I installed a transgo shift kit SK 340. (probably not the best idea as the box wasn't tested unmodified)
Situation I have now is I have reverse and no forward gears. I can hear the revs pick up a little when shifting into D but no drive at all.
what do you guys think? the forums here in Australia are ver limited in their knowledge when it comes to transmissions.
I'm planning on testing the solenoids first up..
Thanks a lot. its a bit of a worry..
Old January 7th, 2019, 18:36
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: transmission upgrade/issue
Unplug the tcu and put it in 1. Bypasees solenoid.
Sounds like a bad shift kit install though.
Old January 8th, 2019, 02:14
Yep sounds like Iíve made a mistake somewhere along the install of the kit.
Does anyone have any resources on this kit? Or on the valve body for an aw4?
Old January 8th, 2019, 03:57
RCP Phx RCP Phx is offline
A little insight.....
https://naxja.org/forum/showthread.php?t=1147175
Old January 8th, 2019, 04:28
Thanks a lot. Seems like a similar problem. Iíll make make sure to check the prv
Transmission Issue egiznad OEM Tech Discussion 3 November 7th, 2015 20:25
transmission/transfercase upgrade? 2stix SoCal Chapter 31 January 20th, 2010 08:41
Transmission issue? Engine issue? kastein OEM Tech Discussion 7 September 9th, 2009 10:48
Transmission Upgrade SUA SPONTE Modified Tech Discussion 11 June 1st, 2007 06:52
Idling Issue After Injector Upgrade XJVenom Jeep Street and Performance 7 October 4th, 2006 16:57
