Old December 1st, 2019, 21:17
Black1990jeep Black1990jeep is offline
Frame Stiffener and Control Arm Bracket
I want to add center frame stiffeners, but see a problem with my drop bracket for the control arms. Should I trim my stiffener on the bottom to clear the drop bracket, or?
see image of my drop bracket on this link.... https://www.cherokeetalk.com/forum/f...3/#post1155581
Old December 2nd, 2019, 05:27
Evan03 Evan03 is offline
Re: Frame Stiffener and Control Arm Bracket
I think I'd cut it off where it wraps around the frame.
You could pull the bracket off and scribe it in but I'm not sure that would be worth while
Old December 2nd, 2019, 12:47
Greenz's Avatar
Greenz Greenz is offline
If it were mine, I would keep the stiffeners intact. You want to stiffen your ride for a reason. So why leave a relative large section unfinished? It's a lot of work either way you do it.
Old December 2nd, 2019, 13:27
jrowell's Avatar
jrowell jrowell is offline
I kept mine intact and installed brackets over them. Welded braces to stiffeners. It's been about 10 years... so far so good!
Sent from my SM-G930V using Tapatalk
Old December 2nd, 2019, 13:34
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
On my 2001 XJ, the dropped bracket braces were removed and then the stiffeners were welded in place. The dropped bracket braces were then reinstalled, bolted and welded to the stiffeners .
The brackets brace bolt holes were enlarged to allow them to bolt up to the dropped brackets, adjusting for the added thickness of the stiffeners.
It wasn't a big deal to do.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old December 2nd, 2019, 20:21
Thanks all for the suggestions and clarifications. Looks like I will install stiffeners intact, then put the drop bracket plate under it, with slotted holes to the control arm mounting unit.
I am pretty sure I will be going with hooligan stiffeners.
Frame stiffener interference IanGlaser-XJ99 Modified Tech Discussion 8 April 3rd, 2019 19:53
Frame stiffener CAD files dude_bonez Modified Tech Discussion 13 February 17th, 2019 07:11
Frame stiffener prep. VAhasnoWAVES Modified Tech Discussion 13 September 25th, 2015 18:30
Lower control arm bracket on frame bent 2000bluexj OEM Tech Discussion 17 December 31st, 2009 17:11
Frame Stiffener Bake Off splitz Modified Tech Discussion 12 August 18th, 2009 21:28
