Old December 1st, 2019, 16:38
RrCoX22 RrCoX22 is offline
Driver Window Grinds When Fully Rolled Up
Driver side electric window will roll down and up fine with no issues but once it's rolled all the way up to the top it will start grinding and act like it want to keep rolling up. Are the teeth on the actual motor shot? What all do I need to replace for the guru's that's had this issue?
Old December 2nd, 2019, 17:57
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Driver Window Grinds When Fully Rolled Up
The only way to know for sure what is going noise to remove the door panel and see what is happening.
To prevent the motor from continuing to run once the window is all the way down or up, there is a circuit breaker, inside the window controller, that opens and shuts off the power once the window reach the end of its run. The rise in amperage, when the rotor is locked, increases greatly and activates the circuit breaker. The circuit breaker may be bad and is allowing the motor to continue running.
The motor's output shaft has a worn gear that may be slipping on the shaft.
Open it up and take a look.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
WTB: driver window motor poomero NorthWest For Sale/Wanted 1 September 20th, 2016 23:35
driver's window not working cbs_24 OEM Tech Discussion 9 March 17th, 2016 09:56
Driver's window won't go up! Reddleman OEM Tech Discussion 5 February 18th, 2011 08:03
98 Cherokee Classic XJ - Fully Built Rock Crawler/Daily Driver Cruzzin_XJ For Sale: Private Party Only. XJ ITEMS ONLY 3 April 22nd, 2008 09:31
Driver window clicks at the top. DesertXJ68 OEM Tech Discussion 25 January 17th, 2007 09:53
