Old November 17th, 2019, 18:41
blu3fan's Avatar
blu3fan blu3fan is offline
changed oil. car dies now.
hey guys. 92 xj 4.0
I changed my oil. now the car is backfiring and misfiring. feels like shes running on 3 cylinders.
Im thinking crank position sensor failed... again...
Timeline---
Changed oil.
Car would not start. just cranked forever.
Fuel pump is on a manual circuit. so its not fuel related.
Car throwing CEL 27.
Just to be sure this was not my distributor wiring at the plug not connecting again. I just soldered the distributor to the harness.
can anyone confirm if the cps when it starts to fail could cause nonstart/misfire ?
Old November 17th, 2019, 18:54
blu3fan's Avatar
Re: changed oil. car dies now.
I might add.
After the oil change and the initial no start.
I fiddled some wires; Unplugged and replugged distributor and cps also wiggled wires around intake since I might have touched those during oil change.
I drove her up the street.
Ran awesome.
Got about a mile up the street. and she died.
Started her up again.
Ran 20 ft.
Died.
Thats why im thinking cps. Bought another one that'll arrive Tuesday.
Old November 17th, 2019, 19:21
blu3fan's Avatar
Sorry - its been a long day of screwing with this thing.
After she died about a mile up the street.
I got her running. Unplugged and replugged the cps.
The last 3 times the cps has died Its been a week of random stalls then wont start.
never had a misfire..
got me home Ran fine. Just Tried to die 2x.. now she runs-- just backfires... not drive-able.
*** of course the day before I take my puppers in for surgery this happens..... ****
Old November 17th, 2019, 19:39
lawsoncl lawsoncl is offline
27 is an injector fault. Check the fuel injector wiring harnesses really well for damage, particularly where it runs along the firewall behind the intake manifold. If it looks pinched, open the wiring loom up and make sure the wires aren't chaffed and shorting together. Check that the CPS wiring isn't touching the exhaust manifold. Check all the grounds, in particular where it grounds to the engine block. You might have knock something loose there. Cap/rotor and spark plug wires all in good shape?
Old November 18th, 2019, 06:29
blu3fan's Avatar
That was the first thing I did.
Unplugged each injector and replugged.
honestly I dont think I hit anything and this is just an odd coincidence.
Starting to think this is either O2 sensor circuit or cps failing somewhere.
Started her up this morning.
started.
Ran fine.
Got about 10ft.
Died.
would not start again.
I mean considering fuel pump is on a switch. this narrows t/s to injector harness.
Distributor failure.
CPS.
or o2 sensor.
I doubt this is tps or iacv.
Its running rich which indicates spark/timing related.
New Cps arrives tomorrow.
after that im gonna check the harness.
Meh....
Old November 18th, 2019, 07:13
Anak's Avatar
Anak Anak is offline
Stranger
I know you said it is not fuel related, but I would slap a F/P gauge on it just to make sure there isn't something plugging the filter or some such issue.
I think it is also worth reiterating the wiring touching the exhaust. If an O2 sensor wire can brush the exhaust manifold it will short out and give you these symptoms. Takes a few minutes to get hot enough to melt the insulation. Upon cool down it may cease to touch and you get to repeat the joy next time you start it up. On mine it was the wiring behind the power steering pump touching the header. I know others have had issues with the wiring further downstream.
Baby it's cold outside.
Old November 18th, 2019, 08:08
blu3fan's Avatar
I have a gauge mounted to the rail 60psi.
Yeah I saw my 02 sensor wiring is a little burned.
I am gonna check that out also.
but its been a little burned for years now..
Old November 18th, 2019, 08:09
blu3fan's Avatar
Before I dig into other stuff.
CPS first. since I happen to change that pos every 2-5 years..
Old November 19th, 2019, 08:03
blu3fan's Avatar
cps arrives today- I will get back with results.
Not hoping for much. but Im sorta thinking the CEL 27 is a separate issue.
Old November 19th, 2019, 14:32
blu3fan's Avatar
pulled the cps in the pouring ran.
Wiring to cps is melted.
this might explain the odd misfire and why it worked after I unplugged and replugged the cps.
soaking wet from removing it- but gonna do the "cut slits" mod so that I dont have to remove these bolts again
Old November 19th, 2019, 15:35
blu3fan's Avatar
so I did some research and found this gem.
https://www.flickr.com/photos/298348...08469/sizes/l/
when I rebuilt the xfer case about a month ago the speedo sensor was so ground down. I could not get the teeth to re-mesh and left it unplugged.
This would explain the code 27.
due to it being in line with the fuel injection.
or at least I suspect it is.
Old November 19th, 2019, 16:35
blu3fan's Avatar
Cps replaced.
Car start up really clean now.
However the stutter still exists.
it feels like the car is out of timing.
new symptom. when the car stutters the rpms on the dash drop like a short.
I think we have a short somewhere. I messed with the o2 wiring.
saw a slight change.
not 100% yet. but thinking bad connection to o2 sensor...
Never had an issue like this before so hopefully its not the main harness or something..
Old November 21st, 2019, 08:03
blu3fan's Avatar
I think my cps connection is bad. Can't seem to find a replacment harness side plug. Probly gonna junkyard run and pull a harness this weekend
Old November 21st, 2019, 17:53
blu3fan's Avatar
Update.
cps wiring is sketching me out. there is a slit the harness by the connector.
since every time car has died recently ive messed with cps.
cutting that part out and making a new "ghetto connector" out of rtv.
will post an update.
Old November 22nd, 2019, 09:46
Skwerly Skwerly is offline
I can't wait.
Could I have my name changed Qban User Support, Questions and Suggestions 5 May 23rd, 2013 20:21
'95 XJ runs for a minute-dies, runs 2 minutes-dies, on & on...... Four2score OEM Tech Discussion 0 June 15th, 2011 08:06
What changed? Tommy4949 OEM Tech Discussion 3 May 19th, 2008 01:17
okay, so i just changed my CPS..... slammed73sb OEM Tech Discussion 1 December 11th, 2007 13:51
XJ dies, unplug something, starts, but dies 5 minutes later KingOfTheHill OEM Tech Discussion 6 April 26th, 2005 12:00
