Old October 29th, 2019, 07:52
Thehowler's Avatar
Thehowler Thehowler is offline
LED dash bulbs
Installed some LED blue dash bulbs in the rig and they look really good. The only problem is they flicker from the inconsistent current produced by the alternator.
Anyone else deal with this and where did they wire in a resister to cure?
Old October 29th, 2019, 08:05
cruiser54's Avatar
cruiser54 cruiser54 is offline
Re: LED dash bulbs
I bought 5 sets from onewaylight.com and installed them on 3 Jeeps and 2 Alfa Romeos with no issues at all.
Old October 29th, 2019, 08:16
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: LED dash bulbs
A good quality 12 volt LED lamp should function correctly with between 6 - 24 volts. I would suspect a dashboard ground issue, or that you got cheap crappy Chinese LED's.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old October 29th, 2019, 08:31
cruiser54's Avatar
Re: LED dash bulbs
And, if we knew the year of your Jeep, we could help you with the grounds.
Old October 29th, 2019, 11:57
Thehowler's Avatar
Re: LED dash bulbs
I will try Onewaylight.com, Thanks
Old October 29th, 2019, 14:47
cruiser54's Avatar
Re: LED dash bulbs
But what if the cause is a poor ground??????
What year?
Old October 29th, 2019, 17:35
Thehowler's Avatar
Re: LED dash bulbs
Grounds are fine, checked it out before I wrote my question, but thanks!
Old December 2nd, 2019, 23:01
tm8chris tm8chris is offline
Re: LED dash bulbs
Does anyone have personal experience with superbrightleds?
Old December 3rd, 2019, 06:28
cruiser54's Avatar
Re: LED dash bulbs
Yes. Some good. Some not so good.
What are you wanting to do?
Old December 5th, 2019, 19:47
Thehowler's Avatar
Re: LED dash bulbs
The blue 194’s have been working perfectly for me.
Dash bulbs sockets broken Tacowhip OEM Tech Discussion 2 May 17th, 2017 07:19
Dash/Instrument Panel Light Bulbs-96 XJ KY-XJ For Sale: Private Party Only. XJ ITEMS ONLY 1 August 26th, 2006 17:43
Bulbs under dash Littlewhitexj OEM Tech Discussion 2 April 10th, 2006 22:14
Anybody ever change OEM Fog Light Bulbs with premium fog light bulbs? joey99jb Modified Tech Discussion 8 November 28th, 2005 00:54
Replacing Dash bulbs in 97XJ John Paddock OEM Tech Discussion 6 April 6th, 2005 12:36
