wolfman_023
- Michigan
Hi Guys,
I'm in a pickle and need some help. I"m going out of town tomorrow morning and I just noticed last night that my brake lights are out. Running lights, reverse lights, turn signals, hazards all work. The third brake light still works too. I've been searching on here and on other forums and I'm confused about how the brakes lights are wired. My rig is a 1999 XJ Sport, 4.0L. A few posts have mentioned that the brake lights run through the multi switch on the steering column. Does that include the third brake light? If so, then I can eliminate that as a possibility.
i'm assuming that since the third light works, my brake pedal switch is fine too correct?. I checked fuse #7 and the under hood fuse #23. (Again, if the third works, those shouldn't be the issue either right?)
I've swapped the bulbs and still no lights. Anything else I can try?
Thanks!
Thanks!
