Wheel Question
flingshot
For some reason I seem to be drawn more to stock wheels so I am considering Rubicon Moabs but I also like the Ravine
The cool thing about the Ravines is that I wouldnt need to buy tires right away as they are 15s.
My question is are the backspacing measurements the same on all stock Jeep wheels? I was hoping the Ravines would give me a bit wider stance as I am rubbing my control arms a bit with 32s.
I have these currently.
Those ravines would look good on your rig. You could always add spacers too.
I believe all of the TJ 15x8s are BS'd 5" over the stock XJ 5.25". But that probably won't help you depending on how wide the 32s are.
So the Ravines are 15x8 and mine are 15X7? That might help a bit as well if that is the case. I am barely rubbing with a 32X11.50. Thinking about going down to Performance tire and wheel. I'm sure they have one that I could mount up and check before I pull the trigger.
Thanks Dutch, I did think about spacers but it would be nice to do it with just the wheels. Might need both.
When I first got my jeep, it had a 2" BB with 31s that were mounted on Moabs. Looked great IMO but it was quicker to get new wheels than re-order the tires I bought. They must have been from a TJ Rubi cause they bolted right up with no adapters. Here's how it looked when I brought it home:
