goodburbon
- Westcliffe Colorado.
While helping a friend change the ball joints on his Dakota we ran into a few difficulties.
1. The original ball joint asembly was riveted in place
2.we ground the tops off of the rivets after 2 ruined air hammer blades because the air hammer was the reccomended course of action.
3. the rivet left in the a-arm would not come out, we beat on it with a punch and RBFH for a while, then decided to apply heat and try again....
here is where safety comes in.......DO NOT HEAT A BALL JOINT! the only thing I can figure is that the grease left in the joint burned and expanded, causing a buildup of pressure behind the ball. after heating for a minute the joint EXPLODED! punching a hole in the plywood we had under the truck to keep us off of the gravel and denting the roof over us on its rebound.
the technique that worked?
cold......after cutting the tops of the rivets off, we drilled them out, not completely,only 1/2 inch deep, and only about half of the diameter, this gave enough play so the punch hit the bottom of the hole andwouldn't mushroom the rivet, and make it tighter.
we tried drilling hot at first because heat softens metal right......problem was we couldn't keep the bit cool enough to hold its edge, so keep it cool.
Just a PSA from me NO HEATING BALL JOINTS!
