Homemade compound set up my buddy put on his 2g eclipse.... Sick nasty! I dont care if you are into imports or not, he made this from scratch. Form an engenering standpoint just amazing. At least to me...
http://www.dsmtuners.com/forums/custom-fabrication/336541-my-compound-turbo-set-up.html
dyno results:
609 WHP and 541 ft/lbs torque. This was at 47 PSI! Click on link below to see an amazing power curve for a boosted motor!
http://www.dsmtuners.com/forums/dyno-talk/378908-compound-turbo-dyno-results.html
Homemade compound turbo set-up. Uses a ported 2G manifold and a fabricated 3" crosspipe. Turbonetics T4 60-1 (.68 A/R twin scroll turbine housing, P-wheel), MHI B16G w/ 7cm housing & 15* turbine clip, twin TIAL 44mm WG's, Magnus SMIM, 1G TB, Fidanza cam gears, SBR/Kinetic FMIC, twin GReddy Type-S BOV's, modified 1G aluminum radiator, Thermal R&D cat-back, homemade 3" SS downpipe, Aeromotive AFPR, in-tank Denso Supra 280lph feeding a Bosch 044, Lucas 1200's, -6 braided fuel feed, Hallman MBC, twin 12" SPAL pusher fans, Taylor 10.4mm wires w/ NGK plugs (br8es), Calan's large filtered catch can, pre-TB meth injection, Race Ready electric cut-out
Engine Management:
ECMlink V3 (speed density), Innovate LC-1 Wideband, Dynatek ARC-2, Autometer boost & oil press, GM IAT, AEM 5-bar MAP
Engine Internals:
7-bolt 2.0L: Wiseco 9:1's (.020 over), Eagle H-beams, M77 rod bearings, ACL main bearings, O-ring'd block, OE composite HG, revised lifters, Kelford 272's, Kiggly springs and retainers, ARP L19 head studs Current spool times: 10 psi @ 3264 RPM 20 psi @ 3720 RPM 30 psi @ 4058 RPM 40 psi @ 4418 RPM
Drivetrain Modifications:
AWD swap'd GST - TRE tranny - Double syncro 1st-3rd, 11% taller first, welded center diff, ACT 2600 PP, ClutchNet 6-puck sprung hub disk, Driveshaft Shop level 2 rear axles, SS braided clutch line, B&M short shifter w/ Symborski kit & tranny linkage shifter kit
Suspension Modifications:
Street: Racing Hart 18x7.5" Z5000's w/ Kumho ECSTA MX tires, Race: Motegi 15x6.5" Traklites w/ Hoosier QTPs, D2 coilovers, Ingalls Camber Kit, Wilwood Dynapro 4-piston calipers, 11.75" drilled and scalloped rotors, Wilwood SS brake hoses, Baer Decela rear rotors w/ Hawk pads, Prothane engine mounts & solid aluminum roll stops
