Leaf Springs ROPXJ35.0
techno1154
In the islands
I came upon a set yesterday at a Pull-Your-Part. They seem to be relatively new and in good condition. A web search indicated they are Rusty's offering and provide about 3" of lift. Is anyone here using them? What are the negatives if I were to install them on the XJ?
I am running an old set.
Another member gave them to me because the bushings are smaller than the stock XJ bushings and (back then) had lasted less than a year. In all fairness, Rubicon Express used the same bushing, with the same results.
I pressed new bushings when I installed them in 2015. After driving it like I stole it, and working it like a truck, I found the overloads had cracked, and one of the replacement bushings looked a little sketchy. After replacing all of them this year, only one showed tearing at the steel center sleeve.
Ride-wise, I have no complaints. Rusty's springs are said to be soft, and these did seem to flex well off road.
attachment.php
