http://www.backcountrycrawlers.com/smf/index.php?topic=2414.15
please follow the link. im havin problems with my XJ
J.
J.
J.
Wait a minute... a carbed engine with a MAP sensor? :huh:
Maybe I'm just an idiot, I don't know much (if anything) about the 84-86 years, and don't know all that much about the 4cyls except for the one I'm working on right now.
So did most cars, starting, I think, in the '50s. The 2.8 boat anchor has the GM electronically controlled carb, which was often troublesome, and always expensive to play with. They started using the carb around 1980, a co-worker had an '80 Camaro with this carb (which was stolen, and a fortune to replace-they were a hot commodity back in the day). Hell, my '78 Firebird had a diagnostic port, although I don't know what it could have been connected to. So, you may well have a MAP sensor on the vehicle, as the system would need input from some sort of sensor to adjust things by.My 85 olds v8 quadrajunk had vacuum advance.
We'd also be kind of pleased if gives you better and quicker info than those Brand X forums!keep us updated id like to know what it was!
Well, I hope you solve your problem and then stick around, because usually what happens here is that by the time you get it straightened out you'll end up knowing an awful lot about not only what's actually wrong but what isn't. Since there aren't a lot of those old 2.5's out there, you may end up being the carb guru!O HELL YA!!!! ive got more info from you guys just today then i have from the past 3 days on the other sites
J.
