Old March 6th, 2006, 06:48
Roxtar's Avatar
Roxtar Roxtar is offline
Best thing to line floor with.
I'm finally giving up and losing the carpet.
Looking for suggestions on what coating to use.
I'd like something that is thick enough to cover seams and offer some heat protection.
Was considering spray-on restproofing/undercoating but it's too soft; will wear out under feet.
Bed liner goes on pretty thin and would be expensive to just add coat over coat to build up.
Anyone ever try that trunk liner that used to come on cars? You know, the black stuff with white speckles in it?
Other ideas?
Old March 6th, 2006, 08:14
Root Moose's Avatar
Root Moose Root Moose is offline
Re: Best thing to line floor with.
There is a product out there called "Noize killer" which is durable enough to go under the floor (i.e. outside). Supposed to be good for heat and noise.
Never used it but it is on the short list for the YJ project. Google should find it.
There was also another product that looked similar that was discussed here in the last few months (wanna say Xmas timeframe). Sounded like it would work well as well.
Old March 6th, 2006, 08:30
Rev Den Rev Den is offline
Rhino.
You have seen mine.
Rev
Old March 6th, 2006, 11:55
Dirk Pitt's Avatar
Dirk Pitt Dirk Pitt is offline
Adam Dowling
I have no idea if this will fit the bill, but thought I'd throw it out there.
http://edesignaudio.com/product.php?...atures&cur=USD
Old March 6th, 2006, 12:17
Roxtar's Avatar
I saw the thread about this stuff. Looks interesting.
I don't think it goes on very thick though. Kinda pricy too.
Old March 6th, 2006, 12:34
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
Search for a thread someplace in between Jul 04 and October 04. There was discussion there about this paint that had ceramic particles in it: it was specifically made for heat (and it actually had some sort of a rating showing it's effectiveness) and sound. You'd want to coat with that and then with herculiner, linex or something like that on top of that.
Old March 6th, 2006, 15:43
hippymill's Avatar
hippymill hippymill is offline
rhino lining or LineX. LineX is probably the toughest stuff out there.
Old March 6th, 2006, 17:50
Lincoln Lincoln is offline
NAXJA Member #321
Another idea:
http://www.jcwhitney.com/autoparts/P...Browse/s-10101
Old March 6th, 2006, 19:36
wolfpackjeeper's Avatar
wolfpackjeeper wolfpackjeeper is offline
I used the bondo stuff, mix it up and roll it on, worked great. Got a gallon of it at Advance Auto.
Old March 6th, 2006, 20:58
Gil BullyKatz's Avatar
Gil BullyKatz Gil BullyKatz is offline
Durabak comes in colors...
I think they offer "Opie Yellow"
Old March 6th, 2006, 21:05
LiftedWood85 LiftedWood85 is offline
spray on bed liner, at wally world in a spray paint can, its rubber shit like 6$ a can, works great last very long and is cheap...( i say lasts long like a year or so, depends on how offent u drive it etc et...
Old March 6th, 2006, 21:25
Kejtar's Avatar
PostMaster General
You mean duplicolor? that stuff sucks and doesn't last no matter how much prep do you. Plus even stuff like LineX or Herculiner will not keep the heat out. For that you need actuall heat isolation type paint.
Old March 6th, 2006, 21:29
Kejtar's Avatar
PostMaster General
here ya go:
http://www.naxja.org/forum/showthrea...eat+herculiner
http://www.partsexpress.com/pe/showd...number=268-232
Anyways, there are a couple options for you to go with. I kind of abandoned the idea as I wasn't able to get the stuff in time before Moab a year ago and I didn't feel like ripping the carpet out since then.
Old March 7th, 2006, 05:49
Roxtar's Avatar
Thanks Remi, this stuff looks interesting:
http://www.hytechsales.com/insulatin...additives.html
It's the ceramic additive, separate from the paint. You add it to your own paint to get the heat shielding properties.
Perhaps mixing this stuff with Rhino or Herculiner would be the way to go.
Anyone tried it?
Old March 7th, 2006, 06:39
Dirk Pitt's Avatar
Adam Dowling
Anyone tried it?
Good enough for NASA = good enough for Cabo Engineering???
Floor pan repair egon Modified Tech Discussion 24 June 7th, 2008 12:46
looking for floor pan Erik Litchy OEM Tech Discussion 9 March 9th, 2008 18:19
last thing I need for my lift, BRAKE LINE winterparker2b Wanted: Private Party Only 0 February 14th, 2005 18:21
Floor repair jp_of_fire Modified Tech Discussion 4 August 5th, 2004 22:02
Anyone have a floor jack? Tom R. Intermountain Chapter 3 August 3rd, 2004 21:01
