Old July 12th, 2018, 06:55
RCP Phx RCP Phx is offline
Camshaft position sensor ?
On a 2000 does it really do anything? I'm assuming the initial timing, the advance curve, and the total timing are all controlled by the ECU.
Old July 12th, 2018, 08:58
old_man's Avatar
old_man old_man is offline
Re: Camshaft position sensor ?
The crankshaft position sensor gives the ECU the information about where in the revolution the crankshaft is at. The camshaft position sensor tells the ECU where in the four strokes the engine/cam is at. In other words. The #1 cylinder does not fire at TDC on every rotation, but every other rotation.
Once that is established, the ECU can easily keep track of it for the duration the engine is on. On a Renix, if the cam sensor is not working, it randomly picks one and tries it. If it starts, all is fine. If it does not, you try again until it starts.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old July 12th, 2018, 10:19
On the 2000-01's the coil rail does fire every revolution!
Old July 12th, 2018, 11:23
old_man's Avatar
OK the coil may fire the plug, but the same synchronization occurs for the injector pulses.
Loveland, Colorado
Old July 12th, 2018, 12:30
I realize that, but what would happen if I changed it say +/- 5* ? Would The ECU automatically compensate? I'm looking to test more timing?
Old July 12th, 2018, 16:15
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
It would affect injector timing, not ignition timing.
You'd want to move the crank position sensor.
Old July 15th, 2018, 07:16
Jeep Driver Jeep Driver is offline
That's correct.
Valve timing, ignition timing, injector timing, all are completely independent.
I just had this argument with the so-called mods on another site, regarding advancing valve timing and ignition timing..........one has nothing to do with the other, advancing valve timing does not advance ignition timing. Actually, what you are doing is retarding injector timing by 2 degrees in relationship to valve timing....if you are doing anything at all.
This is the lock-box that AMC/Chrysler locked you in.
Everyone loves to talk performance..........if you cannot adjust your timing parameters, no performance, and that's where everyone is stuck.
Jeep people cannot get this through there thick heads.
You want a solution? Here-
I have a high-end machine shop making a one-off part for me now, I've seen what they do with a water-jet, gears, mind blowing precision.
Have the tone ring machined off a new flywheel. Have a machine shop cut you a new tone ring. Just as you can remove and replace a starter ring gear, you can do the same with the tone ring.
Flywheel and tone ring will need to be degreed and marked.
With the engine on an engine dyno, begin the long process of timing the ring.
First one will cost you about $10K.
Then spend another $$$$$ finding someone to develop a programmable ECU, or a remap or flashed ECU.
Until then.........you guys nibble round the edges. And even then, the 4.0 has it's own mechanical constraints.
Old July 15th, 2018, 08:33
cal's Avatar
cal cal is offline
Well, that's a theory.
It's a lot easier to move the CPS on it's mounts. Or on a late model adjust timing in the ECU.
Both of which are regularly done.
Old July 15th, 2018, 08:40
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
The iginition timing tables can be changed in anything from 91 and newer, and if I really cared enough about the renix, I could probably make it happen for those guys as well. But it's easier to just get the renix high altitude CPS and call it good.
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231 8.25/D30 ARB's 4.56's 33's deavers and a few other things.
Click here to join the red team
As usual your on Pluto while the rest of us reside on Earth!
There would be no reason to do all that when a adjustment for the crank sensor could be made for pocket change.
You can only change the valve timing with offset gears( I already have that).
The ECU still "mapped" regarding the readings that it gets from the sensors.
Those maps can easily be changed "ALOT" cheaper thru Chris T or Flyan Ryan.
Old July 15th, 2018, 08:53
F'ing bullshit.
What's a lot?
1 degree with CPS??
This discussion has taken place over the years by many, look back on the stroker sites, many have tried to fool the ECU to advance timing.
And if it were so easy, you'd just do it........instead you are asking how to do it.
Again, thick heads.
Old July 15th, 2018, 11:52
cal's Avatar
cal cal is offline
+/- 5* by CPS. Or you can break the tab and rotate the distributor.
AMC actually sold CPS's that were advanced 5* as an option.
Old July 15th, 2018, 11:53
cal's Avatar
cal cal is offline
(and I have been just doing it in my strokers for years)
Old July 15th, 2018, 12:56
So can I assume correctly that with exception of being able to "tweak" a few components, that the "proper" adjustment of different parameters (such as widening the ign timing curve) can only be done thru the ECU?
Old July 15th, 2018, 13:24
Yep.
And once you accept this fact..................
I'm only posting here because, and not argue specifics, I read and read and read all the stroker's posts, just how badass and soforth.
Then right back to the same questions- how do I get more.
You guys are never satisfied, ever. 4.0s leave you wanting.
Well, for all your money and effort......you are half way to a SBC...........lol
That's where I'm going with mine......I got off the merry-go-round long ago.
Camshaft Position Sensor TERRor OEM Tech Discussion 7 May 10th, 2011 06:24
'00-'01 Camshaft Position Sensor Alignment TerraWombat OEM Tech Discussion 3 September 3rd, 2009 07:34
Renix Camshaft Position Sensor? Windowsrookie OEM Tech Discussion 6 March 27th, 2009 20:41
Camshaft position sensor help! Phil OEM Tech Discussion 8 October 12th, 2007 18:04
Camshaft Position Sensor? Rasputin OEM Tech Discussion 5 January 14th, 2006 02:48
