Old July 9th, 2018, 18:34
country2 country2 is offline
Another... got to to replace rusted floors on xj
Hi, I have a 2000 Jeep Cherokee about 135k miles and I know for sure the drivers side floor is rusted out pretty bad have not removed carpet yet to see if any other places are bad but looking underneath and poking with a screw driver its just drivers side.
Now I have done lots of reading and still wondering on installing the panel if I want to/need to weld (don't have a welder but guess I can buy one and yes I can weld but has been a while) or just do the 3m panel adhesive and rivets. I read that using steel rivets about 1" apart is just as strong as welding and so is the 3m panel adhesive. What would you go with? Thanks!
Old July 9th, 2018, 18:51
trippled trippled is offline
Re: Another... got to to replace rusted floors on xj
I would only consider that if you have clean good metal to attach to. Personally I prefer to weld it in tho. really you need to pull the carpet and see what you're up against.
Old July 10th, 2018, 04:52
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
The 3M panel adhesive is faster and easier than welding, and it provides a greater contact area/joint between the panels. I was very pleased with the results when I replaced the floor pan. Front floor pans are not a critical structural member of the unibody, and most of the rust outs occur from the inside due to moisture retained in the carpet and padding.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old July 10th, 2018, 15:48
Hey Tim, did you also use rivets?
Old July 10th, 2018, 18:12
Tim_MN's Avatar
I used a 6-8 self-drilling sheet metal screws. The patch panel floor pan was spread open a bit at the edges for good contact with the remaining original floor pan, and wanted to pop up.
Old July 11th, 2018, 16:13
Thanks for the info Tim.I'm thinking about using the 3m panel adhesive and using rivets to pull it tight.
Old July 11th, 2018, 16:23
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
I saw one thread a guy used fiberglass and por15 then just saturated it an rolled/pressed the material. Looked real clean, wished I could have found it before I had to deal with the same issue.
I used bolts and sealed the pan in with silicone.
If you use rivets just make sure they compress to the thickness of material you using.
Old July 12th, 2018, 03:01
I would be afraid of fiberglass cracking.
Old July 12th, 2018, 17:18
idk. it looked pretty dang tough. Composites are very durable, though I dont believe por15 was intended to be used that way lol
Old July 12th, 2018, 21:33
Actually, they have instructions on how to do just that with their stuff. Think they even sell a kit.
I still would never do it.
Old July 13th, 2018, 17:45
I saw a post other day on another forum some did it to their floor using the fiberglass kit they sell. Looked good but I would be concerned about it cracking since its a uni-body and will flex. Guess a small area would be OK but I know the whole drivers pan is bad pretty much.
Old July 17th, 2018, 18:39
Got another question. I'm guessing most people are drilling out the factory spot weld what is everyone doing to filling in the holes in the frame (Channel)left by drilling them out? Just filling it in with seam sealer? filling it back with weld if welded? Thanks
Old July 18th, 2018, 16:22
Oh, guess I need to change my comments on 3m panel adhesive... I meant 3M Structural Adhesive.
Still trying to decide if I want to buy welder and weld it or just go the adhesive way. Especially now since looks like I will be getting lots of overtime/weekend work pretty much till November so I might have to rush it some.
Old July 23rd, 2018, 12:45
https://www.naxja.org/forum/showthre...081640&page=23
found it, its a good option imo unless you can weld.
Old July 24th, 2018, 14:54
cody4359 cody4359 is offline
Get a spotweld bit so you don't drill thru the unibody and for welding, I think it's er70s-6. Let's you weld without near as much burn thru and grinds like butter for cleaning up. Did my Comanche floors 5 years ago and once I switched wire I could actually weld with my 110v instead of tack tack tack tack
What to use on new floors? alex22 Paint and Bodywork forum 1 July 17th, 2013 09:11
XJ Floor Pan Rusted Floors FAQ ConnorMann OEM Tech Discussion 160 April 5th, 2010 21:20
new idea for the floors AD-8 Modified Tech Discussion 10 September 10th, 2006 16:02
Help me my floors are shot hotroddenal OEM Tech Discussion 17 February 23rd, 2006 07:23
how bad are your floors??? sidriptide OEM Tech Discussion 4 October 17th, 2004 13:41
