Old July 8th, 2018, 13:13
Mozvader's Avatar
Mozvader Mozvader is offline
Need advice from people with experience
Hi folks,
Im looking to pick up a new Cherokee this week but I have some doubts. I haven't seen the car I'm purchasing in person and it's the first time I buy a car from up north and I'm worried about rust. I got even more worried after talking to the salesperson. Lol! She didn't exactly inspire confidence in me.
The XJ looks really clean, it's low mileage, and it's a 2 owner car.
Here are some pics under the hood and of the undercarriage. Do any of you guys with experience buying cars up north see anything I should be worried about?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old July 8th, 2018, 13:20
Overland's Avatar
Overland Overland is offline
Re: Need advice from people with experience
Yeah, it looks like it's been detailed, which means it looks like after they washed everything under the hood, they painted everything black to look fresh. Common used car dealer tactic.
The underside looks especially suspicious. Looks like they sprayed undercoating right over the rust.
Old July 8th, 2018, 13:22
Overland's Avatar
God, look at the front drive shaft yoke. That's indicative of what the rest of it looked like. It's a polished turd, I'd walk unless it was under a thousand dollars.
Old July 8th, 2018, 13:23
Overland's Avatar
Rear shaft, sorry. Looks like the U joint has never been replaced, and the clips are rusted to the yoke.
Old July 8th, 2018, 13:29
Overland's Avatar
They even painted the exhaust, and it has a new muffler.
For what it's worth, the worst place to look is not shown. Look at the front corners of the floor pan, inside or outside of the unibody frame. They tend to rust through right there, and any repairs would be obvious. Probably why you can't see it from the angles provided.
I mean, you could drive it, and it probably looks nice enough on the surface, but should you have to remove any bolts underneath, things are going to break, strip, etc. So if you want to lift it, you have that to deal with right off.
Old July 8th, 2018, 13:31
Overland's Avatar
Oh, and it appears to have cheap Hankook car tires on it, which are like $45 each. Those really aren't much for inspiring confidence.
"Look, it even has new tires!"
Old July 8th, 2018, 13:39
Overland's Avatar
This forum doesn't allow basic members to edit posts, so sorry for the numerous replies. It looks worse every time I look at it. If I were to guess, it's on a used car lot, it was purchased cheap or stolen via "trade in" and was extensively detailed in an attempt to sell it to someone who would never open the hood or look underneath. It's probably listed in the neighborhood of five to seven thousand dollars. Actual value is probably closer to fifteen hundred given the rust, but like I said, they're going to sell it to some kid who doesn't know what to look for because he wants what he sees.
On the surface.
Old July 8th, 2018, 14:01
8Mud's Avatar
8Mud 8Mud is online now
I'd check if it is smog compliant for your local. I may be wrong, but that looks like a resonator after the muffler and not a CAT, which means it may be an import.
I'll never buy another XJ without folding back the drivers and passengers side carpet. And the carpet around the rear wheel wells. Both are often the spots where you find nasty surprises.
All that undercoating may make sheet metal repairs just that much harder.
Old July 8th, 2018, 14:13
Mozvader's Avatar
I ran both major vehicle reports. It's a 2 owner car. The mileage checks out. It's under 100k. Serviced at the Jeep dealer and the exhaust was replaced in April of 2016. I know cars but I don't know rust.
Old July 8th, 2018, 14:36
Heavyopp Heavyopp is offline
What year is this XJ? What is the asking price?
That sure looks like a jeep cat to me before the muffler -- it's not after the muffler
I do not like all that fresh undercoating -- it would have to be a screaming deal for me to buy it
Bring a hammer and tell them you'd like to tap a few places underneath -- bet they won't let you
Where is it? If it's local to me I'll go look at it for you.
Old July 8th, 2018, 14:48
Tim_MN's Avatar
Tim_MN Tim_MN is online now
Freakish Hand Strength
The most common rust areas are behind the rear plastic bumper corners, the rocker panels, in the door bottoms, the top corners of the windshield, and in the front floor pans, all areas that you can see fairly easily. The Cat Converter likely is original.
Overall, average or better than average for rust.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old July 8th, 2018, 14:54
Mozvader's Avatar
Thanks you but it's in Maryland.
That nice clean undercoating does look a bit off but I can't see any holes. Nothing looks corroded away. Everything looks solid underneath the black.
Also there's no rust around the battery tray and the headers don't look pitted. It's really clean under the hood and I don't mean the Gunk engine bright. The metal and all the bolts look clean
Old July 8th, 2018, 14:57
Mozvader's Avatar
I got pictures of the inside door jams and the bottom of the door. Also got pics of the rain gutters and around the windshield. Actually the truck doesn't have any dents or dings at all. If they are there they must be tiny.
Old July 8th, 2018, 15:01
sinat01's Avatar
sinat01 sinat01 is offline
What part of MD? and if its under 100k it may just be a unicorn that was well taken care of. but take a slag hammer (welders hammer whatever you call it) and tap the floor, and the unibody rails. check under it kinda on the inside of the rear quarter panels and feel around the bottom parts of the wheel wells.
And not to hijack but why do they rust at the upper portion of the floor pan? I noticed mine rusted through there the other day and I gotta fix it lol
Old July 8th, 2018, 15:12
Mozvader's Avatar
It's in Edgewood MD. 2 owner car first owner had it 16 years. I checked both reports and service record. Everything matches. No accidents. Under 100,000 miles. I ran the reports myself just Incase and to compare with what they gave me.
[IMG][/IMG]
Lift kit choice, advice or personal experience Lake919 Modified Tech Discussion 12 February 12th, 2016 13:27
People with experience bending uniframe back Kendellgil OEM Tech Discussion 3 January 26th, 2014 20:33
Rubicon Experience/advice 88trailcrawler Sierra Chapter 12 August 15th, 2011 21:54
People w/ Paragon experience, stupid question for ya.. JeepXJ93 Non-Tech / Off Topic 4 March 4th, 2007 18:22
Car audio people, need some good help & advice Double Down Jeep Street and Performance 11 August 16th, 2005 19:32
